Locked up?
GreenMR
Hey,I have a 99 ranger 3.0 flex fuel 2wd it started making this loud tapping noise from the valve cover area and i got it home i thought it was going to fly apart. Oil is full. I put some seafoam in it and started it a couple of days later,still making the loud tapping noise and then it just wentthump and quit. Won't even try to start when key turned on. What is it?
GreenMR
Truck has about 175k
black_demon69
142
AZ
4.0l
from description it sounds like it seized. to confirm try turning crank by hand with a 1/2" drive breaker bar or ratchet and a socket.
truckerdawg
5
GA via NC Mtns.
4"
31X10.50
Pull the valve covers to check for broken rockers. Also could be a thrown rod or piston skirt broke and was wobbling creating the tap tap tap then boom a hole in the block.
GreenMR
what size socket do i need ?
black_demon69
142
AZ
4.0l
don't know specifically but it is for the center bolt on the crank shaft..
usually pretty large.
