look what i found
AgPete139
09/2014 OTOTM Winner
61
Houston, TX
4.0L OHV
Solid Axle Swap 4x4
~9"
35"x12.50"x17"
i think its so weird that people do that (leave their rigs or trucks in the forest like that).
Like, WHY do they do it? Do some kids jack them, joy ride, and ditch them? Or do some guys think that retrieving the trucks are not worth it some times? Ive heard of guys in Magnolia driving so far deep into the woods and get stuck. They say "screw it," and desert them forever.
Lariat
Iowa, in the boonies
When life is passing you by, downshift!
Its amazing what can be found. I've found hammers. Posts, oh so many posts. once i found a whole driveshaft that looked to be from a 70's pickup. Gotta love trash...
Well Pete, I'm gonna come down there and we are gonna go a salvaging.
AgPete139
61
Houston, TX
4.0L OHV
Solid Axle Swap 4x4
~9"
35"x12.50"x17"
ADSM, let's go. Don't expect to find usable body panels; they usually have kicks or bullet holes in them.
I wonder if they'll do that with 37's in the future. It'll nice to know of a place that does them around here, just in case. The vulcanizing seems to be legit.
Nhaz
4
The Great White North, Ottawa, Canada
1998 and a few
Ranger+Ranger+E
4.0 3.0
I have successfully repaired a cut in a sidewall with a large patch inside the tire and Then a tube. drove on it all winter never had trouble. the cut was almost that size.
swynx
9
lewiston idaho
Mazda
i searched around town quite a bit for some one that does the vulcanizing repair. no tire shop wants to touch it, not even the semi truck tire places. seems that mom and pop tire shops used to do it, but theyve lost the art? i guess. i live in a kind of small town, maybe thats the problem. i might try and patch the holy crap out of it and put a tube in it.
straycat
77
02 06 and 2012
Jeeps
I have asked around here at several tire shops that I have friends work at and they all said NO. They would not touch a side wall spilt..EVER. I thought maybe a tube....but they said they would not do it even for their own rides. Just too much of a risk of having somebody getting killed if it lets go. If you were to do it as a spare...maybe so...but not as a DD. Just be careful, Bro.
17,926
SW Iowa
Go to a farm supply store, ask for a tire boot. It is a ginormous patch for just such an occasion. A farm tire place would have one too.
Nobody will touch it for liability reasons.
Junk Collector
Truck of Month
4,839
Rapid City SD
Nobody will touch it? Nonsense. Goodyear and a tire retreading place in town here both do vulcanizing for about $50 and I have had four sidewalls repaired like that.
Before I bought my new MTRs earlier this year, both my rear tires and my spare had vulcanized sections.
The repairs held up really well for several years and never leaked. I would be hesitant to use one on a daily driver or at least not in the front, but it is a MUCH better option than a tube (been there too, they last a very short time inside a radial tire.)
17,926
SW Iowa
I have had good luck with tubes in radials on implements. Shredders, plows and disks personally, and know some guys that run them on the front of tractors for thorn resistance.
swynx
9
lewiston idaho
Mazda
the only place that i havent tried and i just thought of was a place called "commercial tire"
your comment makes me wonder, because i had just gone to a farming store, and was checking up on tire tubes (didnt have one for a 33") i didnt notice if they had ones with metal valve stems iether. but, ive read quite a bit about tubing tires. seems that people use tubes so they can air down and not worry about losing a bead (cheap beadlocks). and a lot of people daily drive tubes. and theres also something called a heavy duty tube for offroaders that holds the bead better or some crap.
im not sure if i could get it vulcanized if i should? or go tube, with a patch? its not daily driven. i put 1500 miles on it in the last year in the mountains.
my worry is that i go snow wheeling almost every weekend in the snow season. i air down without beadlocks between 2.5-10 psi (10 psi is where i start, and the tires air down really well at 10) i dont want the vulcanized section to come apart from airing down.
swynx
9
lewiston idaho
Mazda
almost didnt see your post, this was my original idea, vs vulcanizing. seems like a better outcome to me than worrying about the tire coming apart again while aired down.
tmcalavy
8
Given what you just described, I'd go with a tube. Wonder what the hole will look like with that little bit of air in the tube/tire?
swynx
9
lewiston idaho
Mazda
i wondered that too,and also i didnt want to get water/mud in the tire, so thats why i was going to patch the tire and then tube it.
any one ever run the tubes with the rubber valve stems? id prefer metal..
No members online now.
