rsrob5617
- Oct 2, 2013
- 0
- Ford
I've been driving my ranger around for a couple hundred miles now after I bought it about a month ago. I do check my fluids regularly and have noticed I've been using about a gallon of water every 100 miles. I looked my engine over and eventually found that my heater bypass hose was cracked at one end and then replaced it. A day or so later I noticed it still needed water even after refilling it and bleeding the air out, and now I see moister buildup in the oil, but not so much as to explain where all the water is going. I see no dripping and no smoke out the exhaust. Earlier today I tried to do a compression test to see if the head or gasket is leaking or busted, but I'm not sure if I did it right. I removed all my spark plugs and connected the gauge to cylinder 6 and got around 50 psi then 5 and got 40 psi and 4 had 55 psi.
