Lost two passenger side locking hubs
joescool2008
4.0L OHV V6
Looked like he had an afterthought and typed it out. He posted after you answered one of my questions.
Some pictures to help you guys see what I am looking at.
SenorNoob
579
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
The only thing I can see there is the teeth on the shaft look worn to me. Just like the teeth inside the hub.
If you can run your fingernail over the machined surface on the spindle and can't feel any ridges it's probably good. It seems pretty unlikely that something would be worn perfectly smooth.
AgPete139
09/2014 OTOTM Winner
61
Houston, TX
4.0L OHV
Solid Axle Swap 4x4
~9"
35"x12.50"x17"
SenorNoon, not sarcasm. You responded first while I was topping a response, too. Ha.
AgPete139
61
Houston, TX
4.0L OHV
Solid Axle Swap 4x4
~9"
35"x12.50"x17"
The splines might be a little bit worn. Are you thinking that under torque, it slips in the hub when locked?
Joe, do you have a picture of the washers, lockouts, and retainer clips that you are using? The axle has to stay extended and engaged...
AgPete139
61
Houston, TX
4.0L OHV
Solid Axle Swap 4x4
~9"
35"x12.50"x17"
i still might think the spindle axle needle bearing might partially be at fault... part of the trouble of not diagnosing in person...
SenorNoob
579
Middle Tennessee
245-70-R16
My first ninja. Awesome.
It definitely seems like the shaft is sliding in and out of the hub quite a bit. Does it even have the c-clip installed?
AgPete139
61
Houston, TX
4.0L OHV
Solid Axle Swap 4x4
~9"
35"x12.50"x17"
the retaining clip / circlip that goes on the axle shaft itself.
joescool2008
4.0L OHV V6
C clip and splined washer were installed. The splined washer shows signs of the axle moving and abrading the washer on the splidle. Gonna put the new spindle bearing and seal in anyways and see if it helps.
SenorNoob
579
Middle Tennessee
245-70-R16
Can you post up a pic of your washer(s) please? Just want to check something...
AgPete139
61
Houston, TX
4.0L OHV
Solid Axle Swap 4x4
~9"
35"x12.50"x17"
How did this turn out?
