- Jan 6, 2008
- 22
- Age
- 47
- Armagh, PA
- Ford
- Engine Type
- V8
- Engine Size
- 387 Windsor
- 2WD / 4WD
- 2WD
OK...I've got some issues...other than the voices in my head!!
Years ago when I first built the Ranger it would run 14.14@95mph in the 1/4 mile. The main parts consisted of a .030" over 351W, WP 2.02/1.60 heads, KB pistons, .450" lift truck cam, Edelbrock Performer intake, Prolator fuiel pump, stock ignition, iron manifolds, bent 2" pipes, Carter AFB 625, 3.23 gears, and 28" street tires.
Over the last 18 months I have changed....
The cam from the .450" to a .512" Crane.
The carb from the Carter 625 to a Holley 750.
The ignition from completely stock to completely MSD.
The pump from the Purolator to Holley Red.
The exhaust from mani's to TP Headers.
The pipes fom 2" to 3".
The gears from 3.23 to 3.55.
The tires from 28" radials to 26" Mickey ET Street.
A year ago it ran close to mid-13's w/ the stock ingition and mani's. The headers and ignition were changed over the winter. So I go to the track on Wednesday night and expect big things since she can now fully burn and exhale the spent gases....only to have the dam thing run an amazing 14.1@98mph!!! WTF!!! The 60, 330, 1/8 and 1/4 times are indentical as the old set up with the mph being up a hair on each.
Late in the night I ran into a fella running a VERY similar 351W but his was dragging along in a '69 Mach I. It was running a very similar cam but less compression that mine (9.5:1 vs 10.7:1). With 3.90 gears and 28" tires, he was running deep in the 12's. My gears are 3.55's and tires are 26" so that should be a wash. His car was fully dressed and should be much heavier than the Ranger.
The only big difference in our set ups was the timing. I did not know where to set mine so when I installed the MSD it was at 30 BTDC so I left it there. This guy was running 34 BTDC and went 12.6 sec then bumped it to 36 BTDC and went 12.4 seconds. He said with my compression, I oughta be running 38 BTDC and go from there.
Would that be the big problem that I am not making power?? I am seriously disappointed that I dumped all that cash to go a blazing 3mph faster!!
