Low power/low vacuum
Craig0320
225
Mississppi
Break it right the first time. Fix it better the next time.
You might have to regap the plugs with the new cam. Yes a misfire can cause a low vacuum car situation.
18,009
SW Iowa
fastpakr
2,850
Roanoke, VA
I think the shop is done at this point. They're convinced that it's caused by the cam.
Craig0320
225
Mississppi
Oh damn it does say for stock HO. I am pretty sure the 5.0 ho used the 351w firing order.
fastpakr
2,850
Roanoke, VA
Right. All the later model 5.0's switched to that order, including the explorer engines. It's the same order as it was stock.
Craig0320
225
Mississppi
Well good on that then. So I guessing the valves are staying open just enough causing a compression loss with that cam?
3,614
Do a cylinder leak down test.
fastpakr
2,850
Roanoke, VA
Adsm - are you thinking the cam overlap is allowing too much leak down between the valves?
Craig0320
225
Mississppi
That's what I was getting at in my previous post could be just enough to bleed off some compression during engine operation.
fastpakr
2,850
Roanoke, VA
Maybe. The grind has basically zero increase in overlap compared to the stock cam, but a lot more lift. It shouldn't affect vacuum, and a lot of others have used it on otherwise stock Mustang and Explorer engines without a tune or any of these issues. It's ground for off idle gains, not high RPM power.
All that said, I'm starting to wonder if it's really the cam grind I chose, or if the wrong cam came in the box.
Craig0320
225
Mississppi
I did a lot of reading also and got the same results as you did other people are running these cams without any tune I think you most likely got the wrong cam in the box.
fastpakr
2,850
Roanoke, VA
That could explain why I've needed to use different pushrods and others didn't go through that.
Craig0320
225
Mississppi
Yeah so now you have to think how much more you're opening the valves with a longer pushrods
fastpakr
2,850
Roanoke, VA
It's not an overlap issue. Compression looks pretty solid: 145, 150, 150, 145, 145, 159, 145, 159 for cylinders 1-8 respectively.
Ignition timing is around 10BTDC on cold start, increasing to around 30 after it's warm.
My gut instinct is to wonder if I botched the cam chain installation somehow and stuck it in one tooth back (8*). That could explain the delayed power delivery. Not sure how I could have managed to screw it up, but it seems likely at this point unless someone has a better idea.
18,009
SW Iowa
I was petrified of that when I did mine. What I did was I timed it the best I could and then tried it either other way off a tooth to see if it looked better.
