M5od-r1 rebuild shaft doesn't spin freely
jessefilson94
I just rebuilt my tranny with an overhaul kit and put new hubs/sliders in. After downloading the bench manual for this trans from trs I got to torquing down the front and rear bearing retainer plates and after that I could force the shaft to turn but it was by no means spinning freely.
I am positive that in this state, the shaft spinning will create heat from friction and maybe ruin the bearings......?
All bearings and races went on correctly.
I am thinking the shims might be pressed to tightly to the bearings.
Am I way out of tolerance to the point where I should reuse the old shims if they work?
Or
Should I leave it the way it is?
This is my first tranny rebuild so if any guys with experience with these could give me advice that would be greatly appreciated!
Transman304
43
Morgantown WV
Chrysler PT
2.4
If you can’t fix it with a hammer, you have an electrical problem
You will have to set the end play by the steps listed in the manual. The shaft should turn by hand. Double check the assembly of the main shaft for improper orientation of pieces. Good luck.
17,866
SW Iowa
I ordered the shim kit, checked everything out and ended up using the stock shim.
Junk Collector
Truck of Month
4,806
Rapid City SD
Did you use new bearings on everything or are you reusing your old ones?
I ran into the exact same thing with mine, with new bearings. There is an order of assembly and it seems to me that the countershaft had to be tapped into position with the trans tipped up, bellhousing up. I could not find a small enough shim for the new front countershaft bearing.
What ended up happening was that the bearing was out of spec and too thick. Rather than machine it down and hope for the best or machine a shim, I reused the old bearing and shim and all is well - this may not work for you if your bearing is junk but I would sure check #1 your order of assembly is correct and #2 that your bearings are within spec.
FWIW the bearing by itself is over $75 and the complete rebuild kit I got on eBay was around $100 shipped IIRC. It's ridiculous and that's why I didn't replace it.
jessefilson94
Its been a few weeks spent trying to find a shim kit for the main shaft bearing and I had to order 0.1mm shim from McMaster-Carr for the countershaft shims. After following Ford's specs from the manual I am still not getting it to spin freely...
A) 3.05 B) 7.0 C) 1 D) 2.45
-52mm OD Counter Shaft shim 2.8mm with 0.1mm shims McMaster Carr
79.7mm OD Main/Input Shaft 2.8mm with shim kit from ALLSTATE Gear
*B-[A+t]=0.05-0.15
7-[3.05+t]=0
7-3.05=3.95
t=3.95
3.8-3.9
Tf=3.85mm shim
*C+[D-t]=0.15-0.25
1+[2.45-t]=0
1+2.45=3.45
t=3.45
3.2-3.3
Tf=3.2mm shim
I am obviously doing this wrong
@Shran I used new bearing& races new synchros hubs sliders etc.. from a kit i got on ebay
Did a proper rebuild with pictures and commentation.
I'll try and knock the input shaft around a bit if that's the trick to it but, I can't tell which shaft is the hold up.
BlackBII
Ranger Custom
Truck of Month
982
UT
When I was putting mine back together, I didn't line the "tab" up correctly on the thrust bearing (part number 7C096) that goes in between the input and main shafts. The tab wasn't in the right spot and so when I snugged down the bearing caps the entire assembly wouldn't spin freely at all. I had to remove the input shaft and rotate that thrust bearing to get it lined up correctly. I reused my old shims as well.
jessefilson94
Ookaaay, despite my mild efforts to approach this correctly according to ford specs, getting this back together was even more blunt. I needed more room than was calculated....
Darn quantum physics....
I ended up starting at the calculated width and torquing the plated removing a shim each time.
I ended up with 2.8mm for the countershaft shim which was the original shim width...
Go figure..
And 3.75mm for the main shaft shim.
This was by no means due to an error in my measurements nor was it in my calculations but most likely a subtle variation in particle speed and beta particle radia....
Nvm!
Anyway the eqatuions didn't work out for me not saying they won't for anybody else.
However it was a smart thing to order the shim kits with 0.1mm and 0.2mm shims along with some other e8tz ford shims.. Got it figyawed OUT...!
Thank you guys for the quick feed back btw.. much appreciated
alwaysFlOoReD
5,102
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Thanks for the update.
