eightynine4x4
- Oct 15, 2020
- 178
- New York
- Ford Ranger
- Engine Type
- 2.9 V6
- 2WD / 4WD
- 4WD
- Total Lift
- 2.5" Suspension
- Tire Size
- 31 x 10.5 x 15
Thanks! That’s great to know.Yes, the conversion is just the same locknuts manual hubs use, as long as it's for the right axle (after this many posts I don't remember if you have a Dana 28 or 35...)
Got sick of shopping mind and built a new pin…
For anyone checking in future, a 3/32” drill out and bit segment is perfect. Seems exactly the size of old one.
I just put the scrap bit in a bench vice, allowed some extra material for the break, then smacked it lightly from the side with a heavy hammer and it broke, then ground off say 1/16” of extra material and Bobs your uncle. Just gotta make sure you lay the nut and washer together with the pin inside to make sure it isn’t poking out and grind more if needed. Took maybe 15 minutes.
On a side note, I realized that since this washer also has a notch that fixes to the spindle shaft (or whatever it’s called) that the washer itself is the anchor point for the inner lock nut to not deviate from…. Inwardly. Because it can’t go outward, since the washer is fixed there. So even without the pin, its hard to imagine the inner lock nut moving INWARD at all, since you know it’s receiving force from the bearing. So this pin seems like overkill but hey I’m fine with overkill.
All systems go!
Both drop brackets are installed and torqued. Chanting to the gods that when Iower the truck I don’t discover I’m totally mistaken with my drop bracket size.. again!!
