newnthused
- Feb 29, 2024
- 2
- Los Angeles, CA
- Ford Ranger XLT
It looks like there may be a wee leak coming from my transmission. I believe it's an M5R1.
The leak seems to be coming from the drain plug and maybe a bit from the fill plug.
When I open the fill plug, the lubricant isn't quite level with the bottom of the fill hole. I have to stick my pinky down about a quarter inch before it's wet.
My questions are: what type of lube should I use? The Haynes repair manual says to use Mercon ATF, but isn't that red in color? The stuff in the tranny now looks brown, like oil. But I'm not sure how to tell what type of solution it is and what I should use to top it off?
Also, how would you recommend stopping these leaks?
You can't see the leak in the photo because I wiped it off to check later and hopefully get a better look of where the leak is coming from.
