Max degrees rear pinion angle for short wheelbase, SOA rigs?
organic
4
NC
Like the title says, How much can you clock the rear pinion, especially for a short WB with a soa? Seems like the pinion's pointing towards the sky, is there any problems running it like this? Is the only alternative a wheelbase stretch? Any advice appreciated, paranoid new CJ5 owner.
Todd
HCT
12
Troll land
BIITR
Solid Axle Swap 4x4
martin
26
St Bruno, Quebec
1991
Might be worth mentioning that if you have a slip yoke it would be a good idea to get a slip yoke eliminator kit. it's a very pipular mod on short w/b jeeps.
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Guessing you're asking due to oiling concerns? (how high up is it?)
If you fill the axle up a bit higher than what would otherwise be normal, most likely you'll be fine. Remember that the rotating gears and differential will keep a pretty continuous flow of oil circulating in there as well.
organic
4
NC
Thanks 4x4Junkie, Yeah I was concerned about lubrication issues. Seems like it hasn't been a problem so far. I'm going to drain the rear soon, I'll give it a good look through just to make sure everything's ok.
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Yeah, just keep the oil level up in it, should be fine.
If I was going to guess just by looking at it, I would say my 8.8's pinion is pointed up something between 15-18° (dunno if that's more than yours or not). So far I've had no issues in 25K miles, though the 8.8's fill hole location is also raised with pointing it upward.
organic
4
NC
I haven't measured but my guess is my pinion is about 22-25 degrees(maybe more). The lift was done by the previous owner. The front looks like it was also moved up alittle, not much. I think in doing so the knuckles pivoted down and the caster is way off, I think thats some of the reason why the steering feels a little loose. Any ideas? thanks, organic
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Too little caster angle will make the steering wander with little or no return-to-center, yes.
Better to sacrifice the pinion angle to get your caster angle correct.
