max front driveshaft u-joint angle
nooch450
4
New Jersey
4.0 OHV
How far can I push the front driveshaft u-joint angle?
Would the answer be the Same for the u-joint for the axle shaft for the passenger Axle beam?
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
Front driveshaft (pinion) angle isn't overly important... Up to maybe 10° I don't see causing an issue.
If you're concerned about front caster angle vs. the pinion angle, focus on your caster. Pinion angle comes last (if at all).
nooch450
4
New Jersey
4.0 OHV
Thanks :icon_thumby: I should have more pics of the build soon :icon_welder:
