Mercury Monterey 4.2 to '96 Mazda B-Series
Suzonda
Maine
Mazda B2300
Alright. I know the 4.2 has been discussed soooo many times on this page but this is the only engine that's free to me to work with. I have a wrecked '04 Mercury Monterey that has the 4.2 Canadian Essex V6 that was freshly rebuilt about 8k ago. Thing is I haven't seen a thread that's specific to the Freestar/Monterey Vans. I've heard that because it's a transverse platform that the intake, bell housing pattern for a M50D-R1 (B2300) won't fit on an R2 engine (Monterey), and motor mounts are non-compatible with a Ranger frame, but there are arguments that it'll bolt in with reconfigured wiring, motor mounts, and minor clearancing. I have the complete donor van, I have the truck, and I'm NOT buying any other engines for it. I just need to know which side of the coin is true and which one is BS.
What I know I'll need:
Headers (Or RWD Manifolds)
Different Engine Mounts
PCM (Have 5 to spare programmed for that one van)
PCM Harness (Have 2 to spare)
Flywheel
Clutch Kit
The Rest is suggestions.
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
You're rangers m5od absolutely will not bolt up to the 4.2. You would need to source an F150 4.2 5 speed truck for a transmission and most likely the intake and several other accessories and mounts in order to use your 4.2 in a NS mounting configuration. So basically you need a third vehicle to make the swap happen...
Not a logical swap even having the engine sitting there.
snoranger
Professional money waster
ASE Certified Tech
13,721
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
The Monterey 4.2l was a FWD... that’s a different bolt pattern from the RWD block. The F150 trans won’t bolt up. It should have the same bolt pattern as the 3.0l.
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
Ok so need at least 4 vehicles to make that swap work... :ROFLMAO:
Ranger 2.3 - frame
Monterey 4.2 - engine
Ranger 3.0 - transmission
F150 4.2 - upper intake and accessories
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
curt put a rwd 4,2 in the ranger.
its not an impossible or overly difficult swap....its just worthless compared to a bolt in 4.0
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
change the oil pump/housing/cover every 40k
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
you have been warned
