most comfotably towed with a 4.0 ohv 4x4
snomaker321
mass
4.0 SOHC
Whats the most you would say can be safely and comfortably towed with a 4.0 ohv 4x4 ranger?
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
depends on setup. brakes on trailer and the setup that operates them...and the actual powertrain combination and driving ability of the individual operating the ranger.
5-7k
most guys can take a late model 410 geared truck and tow a racecar on a 7 k trailer no problems at all. say a circle track car or a mustang or their trail b2/ranger ect.
Downey
Muncy, PA
^^^ maybe if you have a 4.0.
but for a 3.0 i wouldnt tow more than 3-4k stopping is the biggest problem. i tow around 5k all the time with my ranger and it makes a hell of a lot longer to stop. esp with out trailer brakes.
snomaker321
mass
4.0 SOHC
ok thanks guys sounds good.
Our main tow vehicle is my dad's GMC Yukon which has a 350 in it. Its getting up there in miles so I wanted to see if a ranger should be fine towing our boat ans snowmobile trailer. Looks like it should be no problem
wahlstrom1
J-man HD Mech
2011 Truck of The Year
Forum Staff - Retired
21
Edmonton Alberta
Towing a boat/sled trailer shouldn't be an issue. As long as you mind your load as far as stopping distances and turning radius's go there shouldn't be an issue. Trailer brakes are always better to have, and if your towing something heavier a weigh distributing hitch (equalizer bar setup) helps with sway and rear end sag.
racsan
4,449
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
mine is good up to about 4,000 pounds. i have the manual trans and 3.73 gears. the biggest problem i have with my trailer is frontal area, its a tall trailer and catches alot of air. even empty it feels like 3,000 pounds and goes through the fuel. small boats and flatdeck trailers are no problem though.
feellnfroggy
28
Knoxville, TN
Hence the OP's request for a 4.0 OHV. And the most you can comfortably tow is based on your own experience, You may have to have 1 bad experience towing in order to know what your limits are, However listening to others is always safer(if you listen with common sense)
Tractorman
GB, Wisconsin
If it's the same guy from RF that you quoted, just ignore him. He's a few fries short of a Happy Meal.
Weight is only part of the equation, anyway.
