MOVE TO FREE section -Last chance! Ranger front suspension parts
laser3kw
4
(actual join date:2001) Rockford, Il
2000 3.0 / manual trans - orginial motor killed by failed CPS at 85k - r.i.p.
June 1 - parts left here via garbage truck :cry::cry:
Moved to free section
Last chance! If it's here May 1, it goes in the scrap!
I need it gone - hate to see it wasted
Listed are parts that were for a 1999 Ford Ranger, 2wd, coil spring front suspension
your research may find other years they fit. Quick search on Car-parts suggest they may fit 1995 - 2011- you must verify
Parts came off a low mile southern truck and have been in storage for 17 years.
(2) lower A-arm
(2) upper A-arm, press in ball joint type (old ones removed)
(2) springs, #5310-AA, not collapsed. Approximately 4"id x 16.00"" x .740" diameter.
all components are used, any bushings or ball joints should be inspected before use and replaced as needed
_____$100_____ or reasonable offer
can meet a TRS member in North central Illinois at a reasonable distance
70415
70416
70417
70418
70419
SenorNoob
569
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
I thought torsion bar meant it didn't have coil springs?
laser3kw
4
Good catch - that was a copy and paste error. I corrected it and added content.
PS - Ford did make torsion bar front end or the coil spring on the RWD models.
Isk Stark
50
The HillBilly
Ford Ranger XLT
5"
Are you willing to part out the upper arms?
laser3kw
4
Yes! I will sell any part by itself.
Upper arms have ball joint removed and used bushings
(thank you for your service )
Uncle Gump
Token Old Guy
13,471
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Moved to the parts for FREE forum per your request....
