Mud Flaps with 3" Lift
RoxytheRanger
Illinois
Hi everybody,
I'm just wondering if anyone with a lift on their Ranger has any good mud flap suggestions for me. I am mostly looking for rear ones, but fronts couldn't hurt either. I have a 3" lift and am running 33's right now. Thanks in advance!
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Dangerrangers
Ohio
94 and 04
4.0 s
Do it right the first time !!!!!!!!!!
Lose the flaps they look hickey anyway !!!!
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
sometimes you have to have them.
85_Ranger4x4
17,905
SW Iowa
I had a cheap set of "4x4" ones from a parts store. As soon as I put 31's on the truck after the bodylift the truck started trying to remove them (they would get sucked into the tire)
So watch out for that.
scotts90ranger
4,400
Dayton Oregon
2.3 Turbo
If you have any fabrication capability making some wouldn't be a bad idea... and looking at the prices on those would be cheaper...
Several years ago (like 7) I made my own, went to Napa and grabbed a $12 Semi truck mudflap that was just a sheet and all black, cut it up somehow that gave me flaps that were tire width and went below tire centerline which covers me legal wise... then went to the steel yard and grabbed some 1/2" square tubing with 1/8" wall I think and another short piece of tubing that that fit into and a couple scraps of 1/8" plate. Cut some pieces of the smaller tube the width of the flaps and found a spot on the frame that wouldn't get in the way of the leaf springs or shackles (not many options...). Then put a short piece of the bigger tube on a plate and bolted it to the frame, then used more of the smaller tube and connected the two, drilled a hole for a 3/16" or 1/4" quick connect pin (kinda like for a tractor 3pt). Those flaps have taken more abuse than I would have expected being welded with a harbor freight flux core welder... they've hit trees, held up the rear of one corner when the shackle hanger broke off... and I think cost me around $20... Sometimes I forget to take them out when offroad, and once forgot to put them on on the road and got pulled over, got a REALLY funny look from the cop when I asked if he wanted me to put them back on on the side of the freeway... he said no for some reason...
