My 44 Knuckle Swap 35/44 Hybrid
disciplerocks
July 2011 OTOTM Winner
53
Evansville, IN
I like it. Thought it would stick out more with those spacers. Whats the offset on the rims?
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
5.0 HO carbed with an np435 and np208
The weight of a v-8 should fix that problem!!!!! Jking. Looks great, how does she drive so far?
disciplerocks
53
Evansville, IN
You get that other beam moved?
97TrailRigDD
August 2011 OTOTM
Evansville , IN.
4.0 OHV
7
murphy north carolina
2.8 v6
I don't know really . But I have new 35's on it locked front and back , so I'll let you know . The 1.5" spacers on the front should be a good test for the wheel bearings .
ok well run it hard and let me kno if u have any problems lol
97TrailRigDD
August 2011 OTOTM
Evansville , IN.
4.0 OHV
Well I put in some 2.75 degree bushing but that leaned the tires in 3 degrees . So I put the 0's back in and Dustin and I lowered the beam pivot bolts to the lower hole . Now the left tire is in 1.5 and the right is in a little under 3 . But right side is sitting .5" lower than the left and the front looks like it's 1-1.5 lower than the back . So I might lift and level the front a little . What do you think ?
Plus it is towed in about 1" right now .
disciplerocks
53
Evansville, IN
If you add spacers under your coils, it will start to move the tires back out.
Or you could order some 3 degree bushings lol.
disciplerocks
53
Evansville, IN
I talked him into some work then I cut out lol. Sorry man, had to for the woman.
97TrailRigDD
August 2011 OTOTM
Evansville , IN.
4.0 OHV
Both you guys took off on me . Jon even borrowed tools before he left . Tires look good by the way .
86 slo-vo
02/2011 OTOTM Winner
36
owensboro, KY
same here :thefinger: wife said i had a little over an hour to do whatever i wanted...10 minutes out of the truck and she said come pick me up..
thanks again, we'll see if i cant ruin some bald tires lol. the truck looks damn good on all 4's
97TrailRigDD
August 2011 OTOTM
Evansville , IN.
4.0 OHV
While making a sharp turn the brake line at the caliper hit the shock . Why don't these trucks have a split system ? I had to drive it home with no brakes not even the back .
disciplerocks
53
Evansville, IN
Damn. Looks like what happened to me outside of Madisonville coming from TB. I had to remove the tee on mine so I only had the front drivers side working, but it got me home.
You get your alignment figured out?
