- Oct 1, 2009
- 155
- Raleigh, NC
- Ford
- Engine Size
- 2.9L, 4.0L
sweet.....thanks again
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Well the lift was about $530.00 but I also had to get extended brake lines, that coasted about an additional $200.00. I also replaced my cv shaft with a u joint style, witch is a must if you lift it more then 2". I used an explorer sport shaft that coast me about $30.00 at the local JY. Then I had it rebuilt and shortened for about $135.00. So total coast was about $895.00Nice build. My 90 is an eddie bauer, and has the d28. I'm not looking at doing any heavy wheeling with it. Wanting to do a lift, just wondering how much time and money did u put into your lift?
Also, if you need some manual hubs for it, I have some extras.
Yeah, It would occasionally light on and off when ever I would put it in 4wheel before the lift and big tires, so I don't think that is a problem. I re-placed the VSS this morning and the rearABS light stays off now. I'm guessing it's been like that for a while. I'm not going to worry about it to much.was the light on before the bigger tires and lift? after my buddy put 35's on his k5, he removed the rear diff cover to change the gear oil and there were a bunch of little pieces like that floating around. he'd been wheeling it for about 6 months after he decided to change the oil.
i agree, rock it until you can throw a disc 8.8 under thereYeah, It would occasionally light on and off when ever I would put it in 4wheel before the lift and big tires, so I don't think that is a problem. I re-placed the VSS this morning and the rearABS light stays off now. I'm guessing it's been like that for a while. I'm not going to worry about it to much.
On a better note I picked up an M5OD 5speed trans today!!! for $200.00 I'll clean it off later and post up some pics!
Oh yeahi agree, rock it until you can throw a disc 8.8 under there
i have a question, the bottom piece sticking out in this pic goes to the speedometer cable, did you have to cut it to get it out? i've been trying to figure out how to get mine out, but it aint workin
