My 93 splash 4x4
CountryDriven
Azle, TX
Alright y'all, I installed my 07 mirrors on the ranger and the difference as stated before is awesome. They look better cosmetically and give me a much better range of sight. Now I did get the powered version and used heat shrinks to connect the original connectors to the new mirrors (the connectors on the 07 mirrors were completely different. After doing that the mirrors work great, much faster than the slash mirrors too. The only real issue I've had is the fact that previously there was rubber around the splash mirrors and now there is just the foam insert. Will water be able to get in or is this sufficient protection? Anyways, here are the pics.
Rangurr
Salt Lake City, UT
4.0 OHV
They look great! I haven't had any problems with water getting into mine. I was a little concerned about this when I did the swap as well. If you do find water getting in, though, it will be a super easy fix.
CountryDriven
Azle, TX
Alright which would be better. A leveling kit or an 2'' body lift? To be honest I wont lift it anymore than that (at-least with my 235 Goodyears). I do plan on doing the 5.0 swap and supposedly the body lift helps with the swap but I have read elsewhere that its not beneficial at all. If it is a huge help I will definitely be doing the body lift instead, but if it makes no difference on the difficulty of the swap I will just do a leveling kit if that is the best between the two. BTW does this brush guard really fit my truck?
http://www.jcwhitney.com/modular-grille-and-brush-guards/p2009515.jcwx?filterid=c2174d658y1993g845u0j1
Im somewhat sertain this is the same grille on this guys splash
http://jrbenek.tripod.com/Splashman/maintruck.html
CountryDriven
Azle, TX
After tons of research I'm considering the 4.0 swap vs. 5.0. Seems like a better way to go, definitely going to wait until my power-train blows up though.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
5.0, hands down. I went from the 4.0 OHV to the 5.0 as well as a 4.0 SOHC to the 5.0, both swaps are well worth the time I spent. I do highly recommend getting a complete donor though. My first swap in the end cost me $150, only cause I didn't sell off parts. My second swap I made about $50 after it was all said and done...
SVT
Rangurr
Salt Lake City, UT
4.0 OHV
Why not expedite the process?? Go play hard offroad until something gives :headbang: :3gears:
CountryDriven
Azle, TX
Yea, I've read that a 1993 or so LTD or Crown Vi. 5.0 & auto tranny would be my best bet for the swap.
Haha tbh I am going to try to see how many more miles I can go on my 3.0. I think it would be sweet to go like 300-400k on the stock 3.0!
CountryDriven
Azle, TX
I'm looking at buying these leveling coils for my truck:
http://www.roughcountry.com/ford-suspension-lift-kit-9264-6.html
Main reason is for the lift obviously, but the other reason is that I inspected the old coils and this is what I found:
Yea that is not good, I would not want to have one of those pop out while trailing. Anyways here is a list I've made of things I need to purchase to do the job. I will be doing a small overhaul of the front end (bushing replacement, paint, shock replacement, diff lube) at the same time also.
Here is my list so far:
R/C 1.5 coils
93 F150 shocks like used here:
http://www.therangerstation.com/forums/archive/index.php/t-51584.html
Adjustable bushings (although I've heard good & bad things about these).
Tools (spring compresses, ratchets, ect.)
Stuff for front end overhaul (rustoleum, bushings, lube)
Please help guide me through this. What type ov bushings should I use? Is there a better and/or cheaper coil? Will this "4.0 only" coil fit? I've read several how-to's on radius bushing replacement, coil removal but still need these specific details. Thanks!
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
No special tools required to change the coil. Unbolt the caliper, sway bar, and shock, then bend the tab holding the coil in. You may need to put a little pressure on the beam with your foot, but the coil will fall out. Pull the radius arm nut off, then push the arm out of the bracket. Some have removed the rivets holding the bracket in and pulled the ra bracket out, and install bolts on reassembly, if your going to lift later this is a good idea...
SVT
CountryDriven
Azle, TX
Being a 3.0 will the lift be more like 2" with these coils?
CountryDriven
Azle, TX
Update: Changed 3 quarts of trans fluid and filter. So far 100 miles and smoother shifting. I used Valvoline Mecron 5 & a Power Torque Filter. Old fluid was actually not extremely dark, it still had a red tint to it. The fluid didn't smell burnt either. Pretty good for 215k miles on original trans! I do have one question though, my magnet didn't have a single shaving on it. Is this good or bad because I read shavings were normal.
Supplies used:
Trans Pan:
Next fluid& filter change I will definitely be adding a drain bolt to the bottom of the pan... this was the messiest fluid change I've done yet!
CountryDriven
Azle, TX
Alright guys here is my budget lift plan as of right now. I'm going to buy new coils(stock hd), 93 f150 shocks, and adjustable bushings from rock auto. I have already purchased 2in aluminum coil spacers that seem really well made. I'm planning on painting my frame&axles with rustoleum while I'm at it to keep the mud from rusting everything out. I will be able to get her aligned at auto-tech (I was in that class last year I can get one done for free). We have an alignment rack and computer so should be fine right? The main reason for this lift is because alot of my friends are into offroading. The splash does suprisingly well on the local small trails and actually does better than my friends 4cly jeep with 32s! But I'm certain that's because of his lack of experience with manual trannys (he just got the jeep). Anyways the trucks body is in really good shape & I want to keep it that way so this lift will definitely help in that aspect. Here's the parts from rock-auto:
-Coils: http://www.rockauto.com/catalog/moreinfo.php?pk=201321&cc=1137912
-Adjustable bushings: http://www.rockauto.com/catalog/moreinfo.php?pk=675146&cc=1137912
-F150 shocks: http://www.rockauto.com/catalog/moreinfo.php?pk=388575&cc=1122084
CountryDriven
Azle, TX
Well I haven't done much because I've been doing a rustoleum paint job on my mothers 280z. Came out pretty nice for the 100$ invested.
Here is a picture of the 280z's paint job:
Anyways I did flush the radiator & change the fluid. The radiator was clogged with rust & gunk so I plan to be installing a 192 degree thermostat instead of my 180 asap because winter is almost here and it never gets past the C on the thermostat. I also did a oil change because it had been 3k miles. Hard to believe how much I've driven the thing. I dont pay for my own gas so I drive it as much as possible! I have had no luck in finding the dana 35 on craigslist, but by using the classifieds on here I have gotten a few leads. May have a dana 35 soon may not but ill make sure to post the installation of that here.
I purchased some headlight covers a while back so Im going to clean my headlights up and install those while Im putting the off-road lights on my truck. The lights Im using are the sets sold at HF. Going to buy 4.
Lights:
http://www.harborfreight.com/off-road-long-range-truck-light-system-3029.html
Should look pretty legit here is a pic of someone who installed these on therangerforum:
No guarantees but should happen soon.
CountryDriven
Azle, TX
Just a picture of the snow here in Texas, the truck drove through it with ease in 4wd:
kryptonitecb
19
Fort Worth, TX
What area are you in? I'm in Fort Worth
Sent from my SAMSUNG-SGH-I547 using Tapatalk
