my b2 build
bronco2fan
10
Copperas Cove, TX.
2.8 V6
2.8
3 inch body lift
Is that the front end frame? If so you've got your work cut out for you. Body shop or BFH action I'm thinking.
Sent from my Alcatel9007T using Tapatalk
Worst city, Pennsylvania
1957
1999
Yeah that is the driver side frame rail. The pass side is still straight. I wish i had some chain falls and some anchor points. A comealong or something. I might try heating it up and a bfh/ jack under it. Its bent all kinds of directions.
Like ive said before i think the easiest thing to do would be to cut off the bent stuff and weld and fishplate a new stub. Where do i get one though? Lol i did manage to get a front stub however i didnt realise that 88 and back is different.. I could put the 88 style bumper on but it might look dorky. However those parts are in the back of my 57 which is in storage for a couple more weeks.
Sent from the wrong side of town using Tapatalk
bronco2fan
10
Copperas Cove, TX.
2.8 V6
2.8
3 inch body lift
Yeah, I'm no help there. My welding leaves a lot to be desired lol. That's why I said body shop. Are you sure that's the only place bent too? I wish you luck with that one.
1957
1999
Oh this thing was bent when it rolled off the factory floor lol. Though from the accident i can tell the whole body shifted back atleast a quarter inch. I did drive it after the accident and it pulls hard to one direction so it could be totally out of wack.
The plan atm is to get everything as straight as i can, replace the pass side lower ball joint throw insurance on it and drop it off at an alignment shop and see what they say.
My welding isnt pretty but ive never had anything break lol. (Knock on wood.
1957
1999
BTW I ordered new body mount bushings from jeffs Bronco Graveyard along with new door window seals and a couple odds and ends from LMC.
bronco2fan
10
Copperas Cove, TX.
2.8 V6
2.8
3 inch body lift
Well I hope it all comes together for you. Hate to see all your work go to shit if it's real bad. When I got slammed in mine, about 20 years ago, the body shop said the only reason they didn't total it out was because it looked too nice to. And I took a hard hit on the passenger side front fender, bent the frame some in front of the wheel. But it rides and drives real well still to this day. So hope your truck turns out good too.
Yeah, I need to order the window seals and anti rattle stuff too. Shit's annoying some days lol.
1957
1999
Thanks man. If its really fubared then well i guess ill have to take out to the mudbog or something this summer but id be suprised if i didnt have it ready for the road.
I just got the bushings in today. Somehow i didnt catch them this morning at work. Ill catch the stuff from LMC. their boxes are clearly labled lol.
1957
1999
Trying to do my body mounts right now. Ive got two off except on the number two location the bushing is stuck. First one was easy cause it was so far gone i just cut the bolt and pulled it out. This ones fighting mee
1957
1999
Its like the upper and lower are stuck together
bronco2fan
10
Copperas Cove, TX.
2.8 V6
2.8
3 inch body lift
Use a chisel or fat blade flat tip to pry it loose. It's only a washer holding it on if it's stuck. WD 40 too, helps a bunch. Good luck....
1957
1999
I tried using a pry bar and a couple other tricks. Pulled out the air hammer and still fought it. I ended up destroying the sleeve. You dont really need those right? The kit says to retain OEM hardware. Well... My hardware is gone. I should take some pics of the bolts and junk.. Well whats left of them lol
Btw ive been spraying PB blaster on the body mounts every couple days for the past two weeks. I have a feeling it hasnt helped much because everything is rustwelded together.
bronco2fan
10
Copperas Cove, TX.
2.8 V6
2.8
3 inch body lift
Yeah, I used PB Blaster for about a month before I did mine too. If the inner sleeve is toast you may have to go with bigger bolts or find something to replace them with. Didn't your kit come with new nuts ,bolts and washers too. Pretty sure the inner sleeve keeps it from compressing the bushings too much too. Found this web site called suspension connection, they got lots of neat shit for Bronco II suspensions.
1957
1999
Nope it only came with the bushings and 2 washers. Ill have to check that out
