My build thread
Harley
Oregon
Ford bronco 2
5.5 in susp 2 in body
Harley
Oregon
Ford bronco 2
I really like your flairs you don't see those around.I like your console too went to the junk yard looking for seats and didn't see any consoles like that.It would be nice to have a way to hold a drink.
I have seen a few consoles but not many in good shape...the flares are really hard to find...
Harley
Oregon
Ford bronco 2
Looks good, keep up the good work. Next is an 8.8 rear diff and the list never ends or you don't have the Bronco 2 fever.
Thanks! I have an explorer 8.8 waiting till I figure what gears to run...also have a 35 diff for the front...that way I can just pull the third member and swap it out after the gear change
trail B2
8
North Eastern Ca.
When I put long arms on it felt better right away too.ľm going to need tires this year I was wondering if your 35s rub on the inside of the tire. I'm lower than you though. Do you know your wheel offset?I like your flairs more but Jim has access to rubber ones that will work good for my set up.
59bisquik
April 2011 OTOTM Winner
Solid Axle Swap 4x4
5.13's with those 35's will work great for you. If you have stock 4.10's now, thats what the gear calculator will tell you also.
4.88's are good for 32-33's and the 5.13's work well for the 35's.
:icon_thumby:
Harley
Oregon
Ford bronco 2
my tires rubbed before i did the cutout flares, even with the body lift...i think i could remove the body lift now and still clear them with the cutouts. it helped me to go to 8 inch rims, my tens really pushed them out there.
Harley
Oregon
Ford bronco 2
:icon_thumby:
i thought about 5.13s but i dont think i can get them for the front d35...i have a 8.8 ill be putting in and i think they are available for that...is that what you are running???
SenorNoob
624
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
Do you have pics of how you did the radius arm crossmember? I'm considering the same thing..
Harley
Oregon
Ford bronco 2
not sure of the exact question....i dont have a radius arm crossmember anymore....do you mean the transmission crossmember maybe? i had to cut the crap out of it to fit the radius arm mounts...im getting ready to make a new transmission crossmember this weekend
alwaysFlOoReD
5,166
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
There are 5.13's for the d35. I own a set.
Harley
Oregon
Ford bronco 2
cool...i just started looking around for gears....do all ifs dana 35s have the same amount of axle splines?? i have an explorer front carrier i want to put the gears in and then swap it with my ranger d35 one
alwaysFlOoReD
5,166
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I think all ttb d35's have the same axle spline count. There is a difference between the ttb [90-97]and sla [98-up] diff' tho, the ttb is reverse rotation.
SenorNoob
624
Middle Tennessee
245-70-R16
This, I'm wondering how it'd all go together.. (Like what angle and location the radius arm mounts end up relative to the frame.) Please take lots of pics if you have time.
59bisquik
Solid Axle Swap 4x4
5.13's are available. However, I dont remember where I got mine (Reider Racing maybe?). I have had the D44 for a long time now. :headbang:
BTW, I also run 8" wheels with my 35's. Gives you the extra bead pressure when aired down, and I think they look better.
Harley
Oregon
Ford bronco 2
I'll try to get more pics up
No members online now.
