my mazda doesn't start
mbastien82
Mazda
I just bought a 94 b3000. when it heats up after a while and i turn it off and try to restart it won't start. If i wait a few minutes it starts. it cranks fine and runs great. please help i need this problem solved. the previous owner said its been doing this for years
AllanD
TRS Technical Staff
135
East-Central Pennsylvania
1987... sorta
'93 4.0
Most likely it's the ignition module.
AD
Orphanater
Mazda
I have had the same problem with my 94 too. every once in a while if I stall it wont start for like five min. but it rarely happens. I don't have any solutions, sorry.
chico4554
CT
what does it do when it wont start? Does it make any noise at all? My truck used to do this. It was random though, not when it was hot. It would make a single loud click noise, and that was it. If i jumped the relay it would start, so i replaced the relay a few times. It ended up being the starter in the end. I think the power wire had a loose connection. Check all your connections before you go buying new parts.
mazdav6
Mazda
Try this!
I had the same problem. Try doing a tune-up. It helped me. I cleaned out the fuel injection, throttle body, cleaned the intake sensors, and changed the PCV Valve. The PCV valve is under $3.00 at canadian tire. If you have to change the module, try going straight to the mazda dealer, it can cost you less than buying aftermarket parts, plus after market parts are junk. However, anything you buy at the ford dealer ,will in most cases, be a rip.
Ranger Dave (B25)
134
RFD/BNA/PHT
'10
Don't vote Democrat.
Sounds a lot like either a fuel pressure problem (leaking FPR) or a failing fuel pump relay.
