My POS Craigslist Special 92 Ranger
ford4thot
New poly leaf spring bushings came in
Gf helped me lift the bed off
Milo started barking at the strange thing in the driveway so I took him out there so he could see what it was haha
ford4thot
I had to run to Walmart and get a second tarp, I knew as soon as I took the bed off we'd have storms
I've sprayed too much PB Blaster the past couple of weeks to just let it get all rusted again
ford4thot
Progress
Til it started raining[emoji35] [emoji35]
Pouring
So...
Always a good decision. Water was so deep on the roads downtown that my front tires were throwing water trails taller than the Jeep lmao sport mode, traction control off
ford4thot
ford4thot
ford4thot
Some slight axle shaft rust
Not surprising, considering....
Cleaned up my garage during the heat of the day since my axle will be living in it for awhile. Almost done when the gf and her mom showed up (six flags tomorrow, taking her mom)
Gf's mom rocks, brought me an appropriately named six pack
ford4thot
Soon....
Front
Rear
Plus installed "new" brake booster
100% new brake system, except for hard lines
Freaking $1000 right there.... money's no good if you're dead though
ford4thot
Work truck went to the repair shop today so I took a paid vacation day and worked on the POS.
Made some progress but not as much as I would have liked, things keep going wrong.
O'Reilly sold me the wrong size axle shaft seals the first time.
New seals in
Picked up a sweet cart from my co-workers garage sale.... $5
The brake kit shipped missing two bolts and O'Reilly didn't have what I needed. Thankfully a hardware store had the correct grade 8 bolts, even zinc coated and matched perfectly
Brackets on
Cleaned up and painted the axle shaft hubs or whatever the hell it's called
$512 brake kit that took a month before it even shipped and I ran into a second problem with it ?? They sent three small and one large centering ring. I need two of the larger ones.
Dif cover on
Still got a little bit of wire wheeling, painting and pinion seal
ford4thot
ford4thot
Axle is "done"... going to get a new O-ring for the speed sensor or rear ABS thingy whatever it is that bolts through the top of the pumpkin. Then all that is left is fill it with gear oil
Going to wait on the pinion seal til I regear, since there was 0 evidence of that particular seal leaking.
I'm so tired of wire wheeling rust.... unfortunately it has just begun. Next up are leaf springs, frame, sway bars, front knuckles.....
ford4thot
ford4thot
If it looks stupid but it works, it ain't stupid
[ame]https://youtu.be/wJ2FeUb63jQ[/ame]
Last one got scared and fell out
One down
ford4thot
Also...
Getting serious now
ford4thot
Had a panic attack and made sure my wheels cleared my rear disc brake conversion calipers... They do!
