Good evening Uncle Gump, My plans this spring and summer are to paint the cap same color as the truck, remove the truck bed and clean,prep and paint with POR15 the underside of bed,and clean,prep and paint with POR15 the frame. Also address anything else that might need attention while the bed is off the truck. I will also replace the rear shocks and check the brake and fuel lines. wednesday I had my inspection station put the truck up on the lift and look over everything. They replace a rear differential cover (pumpkin plate) and gasket, old cover had a hole in it and was leaking, they also replace the left front wheel bearing assembly and dust shield and backing plate. Frame looks really good and someone had allready replaced both rear spring mounts and coated them. So as ive stated before, I really love this truck and I want to do everything I can to preserve it. What are all of the main Ranger Suppliers that you can call and they will send me a parts catalog ? When I had my El Camino's and Chevelle's the main supplier I used was Original Parts Group (OPGI) and they had about everything from bumper to bumper to restore your vehicle. Id love to find someplace like that for the Ranger. I love my topper also. When I do all the mentioned stuff underneath, then I want to coat the inside of the bed myself with that Raptor coating and spray about 3 coats on.
