Ranger Rod
- Feb 24, 2009
- 3
- Ontario Canada
- Ford
- Engine Size
- 3.0 vulcan
OK, first I want to show my appreciation to all those folks who have posted to the threads which have been so helpful thus far.
Outline.... Cracked head in dead of winter, hoping to last till summer I tried can of sealer crap in coolant system against better judgment which clogged rad, which created back pressure in water jacket, which seeped into oil via crack or head gasket, which loosened crap everywhere, which clogged oil pick-up filter nearly solid.
Have re: & re: / rebuilt heads and hence proceeded to remove oil pan (due for replacement anyway) with motor still in truck as I am a backyard novice, while also cleaning pick-up filter to restore oil passage as none has been reaching top end since water jacket was compromised. When inspecting the oil pan for debris as I tend to do I found this piece of metal which I don’t think is either a cam or rod bearing as it is not wide enough to be from rod as-well to big to make way down from top end to oil pan.
Can anyone identify this piece of space junk found in my 1995 3.0 vulcan before I button up the bottom end again???
