Nathan's "The Rangebe"
-Nathan-
39
Saskatoon, SK, Canada
HO 5.0 / 7.3 PSD
Well Ive been on the forum for sometime now, and figured I had better finally make a build thread. I am including all of my older posts, as so people may see the progression of my truck.
-Nathan-
39
HO 5.0 / 7.3 PSD
Hey guys, I've been lurking for a while, and have finally got my hands on a ranger. It is a 1994 XLT 4X4 4.0, it has a 6" suspension lift (NO body lift) and 33X12.50 firestone destination M/T. I live in Saskatoon, and drove to Lethbridge, Alberta to get it. I guess I'll let the pics do the rest. Let me know what you think.
-Nathan-
39
HO 5.0 / 7.3 PSD
Hey guys, so as my truck came from California, and here in Saskatoon its gets to -50 celsius, I figured I'd put a block heater in. I didn't see a DIY anywhere so I decided to make one.
First things first, remove the air box assembly.
Then, remove the inner fender. Honestly, this was the hardest part of the job, haha.
Here you can see the freeze plug you have to remove.
Now, before you remove it, open your rad cap (make sure the engine isnt boiling hot) and then drain the coolant via the lower rad hose...this makes a big mess.
Then, take a punch or screw driver, and beat in the edge of the freeze plug. Afterwards, just haul it out with a set of pliers.
After the last of the coolant has spewed out, give it a wipe clean, and grab your block heater. Here is the motorcraft one I bought from ford for 35$
Now, take a little bit of NON-petroleum based grease and lube up the o-ring.
Take it, press it into the hole, make sure its seated in the whole way around. Tighten the screw...this opens up the wing nut and makes sure the plug stays in place.
Then plug the end of the cord in and run it through the grille or where ever you like. Put the inner fender back, and then the air box.
Make sure to refill the rad until full, turn on the engine, and let it run WITHOUT the cap on in order to get some of the air out. Top up and then youre ready to go :)
-Nathan-
39
HO 5.0 / 7.3 PSD
Original Poster: -Nathan-
Difficulty:
4 out of 10
Time to install: 0.5-1 hrs.
Disclaimer: The Ranger Station.com, The Ranger Station.com Staff, nor the original poster are responsible for you doing this modification to your vehicle. By doing this modification and following this how-to you, the installer, take full responsibility if anything is damaged or messed up. If you have questions, feel free to PM the original poster or ask in the appropriate section of The Ranger Station.com forums.
Brief Explanation: For those of us without tow hooks, this is a great alternative for a place to pull on. The Hidden Hitch receiver is no longer in production, but this Drawtite one is readily available.
Tools Needed:
- jack/stands
- various wrenches/sockets
Parts Needed:
- Drawtite 65017
- 2 – 2.5” X 0.5” grade 8 bolts (optional)
- about 12 – 0.5” washers (optional)
Steps:
1. First you need to get your front mount hitch, I purchased this Drawtite 65017 from hitchesonline.com
2. This is the hardware that comes with the hitch, I opted to exchange the grade 5 bolts that pass through the frame rails with grade 8 bolts.
3. The rearmost bolts pass through the frame rails, utilizing the existing sway bar mount holes. There are nuts welded inside the frame rails. I removed my sway bar previously, but if you still have your sway bar, remove the bolts these bolts.
4. Now if you’re doing this yourself, as I did, balance the hitch on a jack, and raise it into position.
5. It is easiest to start the rear bolts, just to align it, as the nuts are already there in the frame rail. This is where those washers come into play…the hitch is designed to be place over the sway bar mounts, but if you no longer have your sway bar (like me) just place 2 – 0.5” washers in between the hitch and the frame to make up for the difference. *Note – the washers aren’t in place yet in the picture.
6. Next pass the bolts ( I used grade 8 instead) from the inside, towards the side of the truck. I used a washer in between the hitch and side of the frame to make sure it fit snug.
7. Now pass those “nuts on a stick” up into the frame, and thread the bolt into them. They are the middle holes, just for reference.
Below is a picture from the front, you can see the bolt passing from the inside – the hitch – washer – frame – and nut.
8. Now tighten everything up, and happy towing…or getting towed :icon_cheers:
-Nathan-
39
HO 5.0 / 7.3 PSD
look what the mail man brought me :)
Behold...
and also did my one piece driveshaft swap
cut out carrier bearing cross member
and trimmed the gas tank skid
-Nathan-
39
HO 5.0 / 7.3 PSD
hey, had a quick run to the pit, not too many pics sorry, but at least its something to look at. The other rig is a 250 on 35s.
-Nathan-
39
HO 5.0 / 7.3 PSD
got er done....extremely happy :D
-Nathan-
39
HO 5.0 / 7.3 PSD
Alright here are the pics...here is what I started with...a 2 inch block STACKED on top of a 3 inch block. It had HORRIBLE axle wrap, and my springs were inverted (stock ranger springs).
Here you can see the "shackles" ie.... pieces of flat bar with holes...they got replaced with belltech 6400's.
Heres the new set up...explorer 4 leaf pack with a 3 inch block. I double nutted the u bolts just to be safe.
Overall Im quite happy, i have little if no lift, but I managed to get rid of the 2 inch block. There is no more axle wrap, and it drives so much nicer, the ride is quite a bit softer. I think it will flex out quite a bit more as well.
-Nathan-
-Nathan-
39
HO 5.0 / 7.3 PSD
Rant...
So I have recently swapped out my 3 73s for 4 56s, and put a locker in the rear as well. I was surprised to find out that when I drained my diff oil, that the cover was made of some sort of composite or fiberglass. I am NOT comfortable covering up hundreds of dollars of investment back with a plastic cover.
Solution...
Well, after a suggestion from a good buddy of mine, I ordered a new diff cover, and figured Id show you guys. It is from GreatLakesOffroad, and is STOUT. The mating surface is 1/2 inch thick, and the rest is 1/4. The strip up the middle you see is an ADDITIONAL 1/2 inch strip of steel added on top of the cover as added protection. It also has drain and fill holes.
Im pretty stoked to get it painted up and installed, give me some ease of mind.
Cover....
Drain hole...
Fill hole...
-Nathan-
39
HO 5.0 / 7.3 PSD
Hey guys, regeared my rear a while ago, but didnt have time to do the front, so I tackled that this weekend, heres a couple of pics.
carrier with old bearings off and ring gear removed...you can visually tell the difference between teh 4 56 and 3 73 ring gear eh?
oh and this thing is tits for removing carrier bearings ;)
the case is there empty with new seals, along with teh pinion and a bunch of new bearings:
everything installed temporarily, backlash checked and ran a pattern. I used my dana 35 skid as a holding jig ahaha. (decent drive pattern too eh?!)
while the axle shafts were out i swapped in new SPICER 5-760x u joints.
Oh, and just for comparison, here is a Dana 35 u joint next to a Dana 28 u joint...
peace
-Nathan-
39
HO 5.0 / 7.3 PSD
hey, snapped a few pics, let me know what you think
-Nathan-
39
HO 5.0 / 7.3 PSD
Hey guys, so while I was regearing and had the front tore apart, I bolted up a skid that plumcrazy had made up for me....anyways here they are, enjoy :)
-Nathan-
39
HO 5.0 / 7.3 PSD
Hey guys, got it all done.
Made up a battery tray from 3/16 1" angle. Just cut the 45, bent it up and made sure it was square, and ran a bead.
here is the square base all welded up.
then i welded nuts to it, so i could use my hold down i purchased from princess auto...and of course a test fit.
then i had to add a bracket to attach it to the truck, used more angle.
here is the battery tray all finished (minus paint). I drilled two holes in the bottom bracket for bolts, and welded two studs on the side to attach it.
Here are a couple pics of how i mounted the tray in the engine bay. I used the space in front of the washer fluid/overflow reservoir. Almost like a second batt was made to go there.
these are what i used to connect the 1/0 welding cable between the batteries, as well as attaching the pre-existing wires. They are called termination lugs, work AWESOME.
Here is the second battery installed and wired up.
and here is the first battery, i added a hold down because for some odd reason mine didnt have one. I also rewired everything using the new connectors. Oh, and i also used new gold plated terminals
And here is the money shot, both new batteries, 1/0 welding cable connecting them, gold terminals, and new hold downs.
almost as if it came that way from the factory :)
-Nathan-
39
HO 5.0 / 7.3 PSD
I added another ground cable today, just for good measure, and in case youre wondering if the cable I used was big enough, heres what 1/0 welding cable looks like to my thumb, and an olfa knife. cheers. Oh, also cleaned my MAF for good measure.
-Nathan-
39
HO 5.0 / 7.3 PSD
finally got around to installing my diff cover, and setting up my cb/antenna
:icon_thumby:
