need A/C vacuum diagram
John H III
My 99 blows out of the vents while at idle or stopped but when under load it starts to blow out of defrost vents. I know its a vacuum leak but don't know if behind dash or somwhere under hood. only thing that has changed is transmission was rebuilt a week ago,before that it was fine. Any suggestions
Wicked_Sludge
43
Westport, WA
3-point-GO
sounds like the infamous "blend door" issue. search around a little, lots of info on the subject...
John H III
Fixed
The vacuum actuator for the front hub was leaking,bypassed it & a/c works fine. Already locked the hubs so don't need tha vacuum anyway
maskale
where is the actuator, I am having the same problem. what exactly did you do?
John H III
on passanger side.down around coolant reservoir,my vacuum hubs went to it. to bypass it get some vacuum T's and bypass
