Need heat tape/insulation for evaporator box.
Bgunner
1,086
Western Mass.
Ford/Ranger XLT
225/70/R15
So I walk out my door today and noticed some of the insulation from around my Evaporator box was in a neat pile under the motor of the truck. Squirrels are at it again, looking for nesting material.
I have never seen this on a shelf in any auto part store and am wondering where to get this insulation/tape to replace it? I know it is out there I just am not sure where to look for it. I'm hoping someone here has replaced it and knows where I can get it from.
8,372
Wrecking yards have lots of it :)
Auto parts stores have it in rolls, ask for heat shield insulation
Craig0320
225
Mississppi
Break it right the first time. Fix it better the next time.
I used adhesive backed thermo shield I bought off of amazon when I installed my headers. It made a heck of a difference.
Bgunner
1,086
Western Mass.
Ford/Ranger XLT
225/70/R15
Thanks for the response RonD, I found heat reflective tape but the original has insulation in it. Does the tape work as well as the OEM installed stuff?
8,372
You need the stuff with insulation.
The heater box needs to be insulated for its use, in the summer using AC, and winter using the heater
The heat tape would be OK, but not as GOOD as even a thin layer of insulation.
The insulation holds the heater box temp as driver wants it, hot or cold.
The reflective surface is just for engine heat really
Bgunner
1,086
Western Mass.
Ford/Ranger XLT
225/70/R15
Update on the search for insulation:
I have called all my local auto stores and none of them can get it. One did recommend going to a hardware store and getting foam insulation that can handle heat. Is this a viable option to replace it?
BlackBII
Ranger Custom
Truck of Month
982
UT
That's what I did
A/C and heater box insulation is looking a little old, let's fix that
15mm self adhesive foam with foil
All insulated. The foil was a little thin so I added some foil tape to it
Bgunner
1,086
Western Mass.
Ford/Ranger XLT
225/70/R15
Thanks for the reply, I will check the hardware stores then.
