Need Help-4x4 frustation
RangerJ
North Georgia
I have a 1994 Ranger 4x4 manual tranmission,4x4 is push button on the dash.
I have replaced the 4x4 control module.dash switch,transfer case shift motor,and the pigtail in the dash behind the 4x4 switch. 4 high works everytime with no issues but 4 low has issues still,when I engage 4 low sometimes it works great and both the dash and switch light come on,then it is sometimes difficult to disengage,then later the dash light will not come on and it takes a while of pushing the dash switch to engage. And sometimes the 4low dash ( switch) light is on without 4x4 being engaged.Any help,advice will be appreaciated.Thanks
8,372
Reads like wiring, of course.
4low(manual trans) requires clutch pedal to be down all the way, Clutch switch closed.
Speed sensor, yes, 1994 has one on speedometer cable hookup, on transfer case, it needs to be working and showing 0MPH, this VSS sensor is also used for cruise control
I don't thing brake pedal needs to be down on Manual trans, only on automatics
These wires all go to the 4WD Control module, and need to be set or no shift to 4Low
I posted the 4WD wiring in this thread: http://www.therangerstation.com/forums/showthread.php?t=170637
1993 and 1994 are the same
RangerJ
North Georgia
Thanks Ron,I have noticed that the speedometer,will jump 70-80 mph while I am going 20-30 mph,that may be my problem
8,372
Speedometer in 1994 uses cable drive
VSS was just for computer, cruise and 4WD
Jumping cable drive speedo needle could be a broken wire on the cable, it catches and releases on the sheath while driving slow, at higher speed it can go away.
But could be worm gear on output shaft, maybe driven gear, but less likely
Fordfreak11
Ford ranger
91 4x4 don't work
I just didn't swap to 4.0 everything works just fine. The only thing that don't is my 4x4. The harness from the 91 4.0 was 2wd auto but my truck is 91 4x4 5 speed. I fixed the wiring so my clutch pedal works correctly by wiring nss. But 4x4 don't work. There has to be away to find wires and make my 4x4 work again. I just am not having luck finding what wires go were. Or info on how to get it to work.
AzLizard
13
TUCSON, AZ
1985
4.0 2.8
Cured mine of all that crap by swapping in a manual shift tcase.dash lights are the only thing that don't work.
Fordfreak11
Ford ranger
I might have to but I'd rather try to just wire it so that it all works right since I'm this close to having it stock again.
8,372
Happy Holidays
Did you download the wiring diagram for 1993 4WD PDF from the link I posted in #2 above?
If module has power with key on then when you select 4high module will send power to shift motor, if motor doesn't turn then 4WD light will flash indicating a problem.
If you are not getting the flashing light then module most likely doesn't have key on power
1994 and earlier module info here: http://www.therangerstation.com/tech_library/4wd_control_module.html
Shifting between 2WD and 4high, either way, doesn't require speed or clutch input, it is "shift on the fly" 4WD, so should work while driving or stopped
4low requires, 0MPH and clutch pedal down, also read a recent post that Parking brake needs to be on, but never heard of that before, but ONLY for 4Low
No members online now.
