If I can remember I'll get you a pic of the vac diagram. Can you describe which vac lines you are having trouble with? I feel like I know the vac lines like the back of my hand.
Hey thanks!!! actually i think the ones towards the left rear of the engine give me the most problems. I did remove the air supply pump so the one(s) from it blocked. I put new oil seals on the eng and painted it as well as everything under the hood over the last 2-3 months and can't remember where thins go....have a haynes manual but does not help....also waht are the two parts that the vac lines originated on the intake manifold called? grrrreatly appr any info....pappy
For
a small yearly donation, you can support this forum and receive a 'Supporting
Member' banner, or become a 'Supporting Vendor' and promote your products here.
Click the banner to find out how.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
