Need help about wheel bearings 1994 ranger
Maxsevich11
21
Ukraine
Hello, guys.
Please help me with a question.
I have a 1994 4wd ranger. Yesterday I tuned and greased the front wheel bearings, but did not grease the spindle surfaces where the bearings sit. Is this a mistake and needs to be redone, or is it normal? I even degreased the spindle surface.
Thank you.
Junk Collector
Truck of Month
4,850
Rapid City SD
It’s fine not to grease the spindle surface.
Junk Collector
Truck of Month
4,850
Rapid City SD
Thank you. So I don't have to worry about the spindle overheating and the wheels falling off)?
Nope, as long as your wheel bearings are packed with grease, you're good to go. The spindle just provides a surface for the bearings to reside, they should be be spinning against the spindle.
Junk Collector
Truck of Month
4,850
Rapid City SD
Does this look like a normal grease pack?
Hard to say without seeing how you did it, but this is how it's done - skip ahead to 10:00 - that is a 2wd application but it is similar for your 4x4 truck
No need to grease the lug studs, also wipe off excess that is on the lock nuts & everywhere else, it has a tendency to migrate out to other places.
