Need help how to remove oil pressure sensor 88 Ranger
88 XLT Ranger
Pollock Pines Ca
2.9L
My 88 Ranger 2.9L oil pressure sensor is leaking. I bought a socket that fits it. The motor mount is keeping the socket from going on all the way. I even took the black plastic cover off the sensor. Any help is much appreciated
broncc
571
MA, USA
Ford Bronco II
5"
Giving my truck more money than it deserves.
Adjusting wrench, pipe wrench, vise grips, channel locks.... just turn it counter clockwise.
Bear in the woods
94
Corinth Ms
Ford ranger XLT
2.9 in 90 , 4.0 in 99
30”
There is a tool for doing plumbing work. It’s like a mini pipe wrench end turned sideways on a T HANDLE. it would work well 4u .
Dustin_89BII
23
Oregon
I got to mine with a wrench, handle pointing into the 7-8 o’clock range. It was tight and slow, but worked. The tool from the previous post sounds awesome though! Good luck 🍀
SenorNoob
589
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
That tool is called a basin wrench for anyone trying to look it up.
Northidahotrailblazer
464
Northern Idaho
Solid Axle Swap 4x4
8 inches
37"
I just replaced mine on my 4.0, which im 99% sure is in the same place. Used a wrench, came right off. Used a 1 1/16 wrench I think? I'm pretty sure it was around that size anyways.
ericbphoto
Overlander in development
16,722
Wellford, SC
6"
Crow's foot may be the ticket.
