Need help with starter
Vexarana
The previous owner changed over my battery terminals to boat quick disconnects and I have had issues with the wires working loose so occasionally I've had to go in there and tighten it down.
Its a 91 4.0 so there are the two wires for positive and negative which need to be connected to hook up for it to start.
Normally, a wire works loose and I take it out and recrimp the connector on it and it starts fine.
Last night I was at a coworkers house because I'm housesitting this weekend and it wouldn't start up when I tried to leave.
Power is fine, all lights work, headlights work strong, don't need a jump.
All the battery wires look to be getting a good contact.
But no crank. Just "click click click" when I try.
One important thing I know is that when I try to crank it, all the lights on the truck go out. If I have door open and dome light is on, I crank and it goes pitch black.
My supervisor said he had the exact same issue and it was his starter. Found a decent deal on one for $120 local, so I can get it and hopefully install it today. But I was planning on changing the terminals first. If anyone has experience with this and I might be overlooking something, please speak up.
Oh, and I did check the ignition fuse. The 60A in the distributor box. It's fine.
Dugan
12
New Castle, DE
Ford, IH
2.9L, 355 SBC
Your terminals are loose. And or your wires are bad
Vexarana
Does the click-click mean that the smaller wire is not hooked up properly? Or one of the big wires isn't getting a good contact and the amperage isn't getting to the starter properly?
EDIT : Hooked up / good contact / going bad interchangibly.
martin
26
St Bruno, Quebec
1991
It's a bad connection on one of the big wires, somewhere, check both ends of both big wires.
