Need some help from the laptop techs.
BRUTUS_T_HOG
ASE Certified Tech
36
Rainier, OR
2.3L
I have an Acer aspire one d255e that won't boot.
a while ago i replaced a cracked screen and have had the connector of the screen come loose a couple times. today it happened after my wife used it and i told her i'd fix it when i got home.
i get home and check it out, started by popping the trim off and finding the connector halfway popped out, i pushed it back in not realizing that she had left the laptop powered on.
it turned off, and after plugging the screen in and putting it back together the computer won't turn on.
the power button either does nothing, or it will sometimes turn on for a few seconds and then shut back off. i've tried with the battery removed, and with the battery in and power cord removed. same results.
im pissed. im thinking it shorted out the motherboard or something, but i don't know how to check. unplug the ram and see if it beeps? any way of fixing something like that aside from replacing the MB?
EDIT: i've also tried starting it with the screen unplugged, same thing
James86
10
55381, Minnesota
2012,
Ford,
Ford,
3.0 Flex Fuel, 2.5L, 3.3 Flex Fuel
WHY DO I KEEP BUYING DODGES?!?!?
Sounds like you fried something. I always make sure a laptop is powered down AND the battery is pulled before the screw driver is ever pulled out. It's no different than your vehicle - don't you make sure the thing is off and disconect the battery before tearing into that? It's a harsh lesson, but even when you do everything right, I've had to do a laptop mobo or two before myself just from age or bad design and it's nowhere near as fun as a desktop. If it won't power on, the board is likely fried. Somewhere online there may be an Acer specific diagnostic, but I'm thinking it's probably dead. :dunno:
Spitfire1975
16
Oregon
2.9
Probably fried....BUT... just for fun, unplug it, take the battery out and then hold the power button down for 15-20 seconds or so. This supposedly discharges ALL possible remaining power in the system and give you a true reset.
I doubt it will work though...
DFracing
power supply
James86
10
55381, Minnesota
2012,
Ford,
Ford,
power supply
For the LCD perhaps? I know they often have their own converters sine AC adapters only supply one voltage. I have an Acer Aspire One and considering the running cost of a netbook, dont bother replacing the mobo if it's fried, just consider it an excuse to upgrade. I got my compaq with the new AMD fusion dual core's and they blow an Intel Atom oout of the water for similar if not less money. I still have my Aspire, but I prefer my Compaq CQ-57 which cost me less.
BRUTUS_T_HOG
ASE Certified Tech
36
Rainier, OR
2.3L
the aspire one is/was my work computer..
its not that is doesn't power on at all. it turns on for a few seconds, power light lights up and fans come on, no HDD activity. and it shuts off.
and yeah i should have unplugged the battery, i usually would i just wasn't paying attention.
this just pisses me off SO much! i don't have the money to just replace the whole thing over carelessness. FUUUUUUUUUUUUUUUUN!!
would there be any way to be sure which part is burnt out?
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
Yes, but it is sometimes more expensive than swapping parts out trying to troubleshoot an RBV...
Was the unit using A/C or DC when you did this...and if DC try pulling the battery out and using AC only...
You are getting power so it's not likely the power supply...the system is doing a POST (power on self test) and halts when it detects a problem...the problem is a major part is simply responding...do you have an option for external monitor???
Using an external monitor and booting into safe mode (press F8 as soon as it starts booting and tap it a few times till you get a boot option menu) will give you a halt on drivers loading...and sometimes you can see where the problem is...
If it doesn't get that far...you may need to take it to a shop to have them test the components...
BRUTUS_T_HOG
ASE Certified Tech
36
Rainier, OR
2.3L
it was plugged in, the battery was installed. i've tried it with the battery out and a/c power only, and i've tried with battery power only, and i've tried with the screen unplugged, it still does the same thing.
i'll probably just have to try my best to figure it out, i would never pay someone to fix something i'm capable of doing
AllanD
TRS Technical Staff
135
East-Central Pennsylvania
1987... sorta
'93 4.0
Power disconnected, battery out, REMOVE both memory modules, reinstall one and try running it with one.
try it in both slots.
if that fails try it with the other module.
AD
BRUTUS_T_HOG
ASE Certified Tech
36
Rainier, OR
2.3L
The RAM chips correct?
I still haven't even touched it yet.
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
If I recall correctly, to work on the internals of a laptop you need a food chisel to split the case open...takes a fairly good crack with the hammwe though...
But I do recall a test like AD suggested...been so long since I troubleshot a laptop...but that would tell you if it's fried RAM...system won't boot with bad RAM, Video, or HD controller...we used to use beep codes to TS systems...not sure if they still put them in computers any more...but it's only good for POST errors...and it doesn't sound like you're even getting to the post...
AllanD
TRS Technical Staff
135
1987... sorta
'93 4.0
Yeeah, the RAM modules which are usually accessable through an access panel on the bottom on most notebooks.
You'd be suprised how many "no-start" problems are caused by a bad or incorrectly seated RAM module.
AD
BRUTUS_T_HOG
ASE Certified Tech
36
Rainier, OR
2.3L
Today i messed with it some. Found that its now only powering on when using battery power only.. will not power on if the DC power is plugged in.
It still shuts off within 10 seconds though.
I have to remove the keyboard or something to access the RAM.
I found a common problem with BIOS so im going to try to flash the bios too
EDIT: Just tried with the RAM removed.. same thing, no beep at all, also tried unplugging hard drive...nothing
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
Did you try it with on RAM chip installed or completely removed? It needs at least one installed...and swap in/out with the other one...if still no boot then it may be a mobo issue or power supply...I'm leaning toward the mobo...but power supplies can give partial boots and then fail...and if it at least boots with the battery (is the battery fully charged???) and nothing at all with the AC then that's another strong possible...
BRUTUS_T_HOG
ASE Certified Tech
36
Rainier, OR
2.3L
it only has one RAM slot and there was no difference with the chip in or out.
the first time it happened the battery was charged, now i don't know since its been sitting, but the symptoms haven't changed at all.
it looks like buying a complete parts laptop would be cheaper than buying the motherboard alone so i might just have to do that
  • ryan
    Forum Administrator
