fordman49450
- Aug 7, 2007
- 0
- Michigan
- Ford
ell, on September 11th my mom was driving my truck ( I loaned it to her for 3 weeks or so, her car has engine problem and she needed my truck for work) and the truck quit pulling. I went and inspected it and believed the clutch was destroyed. I removed the transmission and sure enough, it was in pieces. This truck has had a shudder on take off ever since I have bought it and I inspected the flywheel and noticed that it was extremely warped and not flat anymore. Also upon removing the shifter on the inside of the truck so I could gain clearance to remove the trans I noticed that the stub shaft was loosed and had a sloppy fit. Upon removing the trans and the stub shaft I noticed that both of the plastic pivots for the ball were no longer there. Also I noticed that the tail shaft housing was leaking on the trans. I ordered all the parts and I replaced all of the shifter parts, I resealed the tail shaft housing and also resealed the rubber shift plugs just for prevention. I also replaced the clutch, pressure plate, slave cylinder and flywheel. Also at this time I am swapping the 2 piece driveshaft for a 1 piece. I installed all components and the clutch feel is a night and day difference and no shudder. it shifts great and the shifter is nice and tight. Hopefully this will be the last of major repairs for a while.
