NEW, IMPROVED RUBBER
pjtoledo
3,017
Toledo Ohio
Fords
3.0 2.3
FYI, BFGoodrich has recently released all terrain KO3. an improved version of the KO2.
rusty ol ranger
2.9 Mafia-Don
7,756
Michigan
177 CID
They have? How recently? I just bought KO2's last summer
EDIT...
Just googled them...not sure i like them...the tread looks super close togther and they dont seem to look nearly aggressive as the KO2's...
KO3...
KO2...
The new ones look to goodyear duratrac'y
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
TRS 25th Anniversary
12,871
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
sgtsandman
Ham Radio Operator
12,871
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
A bunch of great input, ideas and feedback. Once I find either a type of product or specific manufacturer that suits my mission (daily commutes and cross country towing), I will continue to use it until it is no longer available or the quality diminishes.
The current front runner is a newer tire from Mickey Thompson called the "DEEGAN 38 A/T"; the reason for focus on this tire is it most closely resembles, in both tread design and performance characteristics, the former high mileage AT I've used which after 19 years have just started to dry rot. The other side of my thought is that the Mickey's I have are great, long lasting and perform very well in their designed job.
What I do not know is which version is better suited to my mission, the Lt or the SUV version:
• 33×12.5r15
• 285/75r16
Unfortunately for me, I do not fully understand how the load rating will translate to premium function while towing a modest camper (2,500-4,000 lbs).
If I understand LOAD RATING correctly, I may be better off sacrificing ride comfort for strength. For example:
- 123 load rating will be a stiffer tire with improved stiffness/strength while towing
- 107 load rating will offer more comfortable ride when not towing
Do I have that correct?
While I don't have it completely nailed down, a 112 load rating, which is what is on my 2019 right now, is roughly equivalent to Load C. I've yet to find a chart that gives equivalents of the numbered load rating to the letter load rating system. So, you sort of have to guess at it.
As far as ride comfort, load rating does play a part but side wall plies contribute more. A 2 ply side wall is generally going to ride softer than a 3 ply. The BFG KO2 and Falken Wildpeak 4W tires have a 3 ply with load C from what I'm understanding. The rest only 2 plies. The Falken 3W tires only have 2 plies in the load C but have 3 plies in the Load E. This is all based on information passed on by others. So, YMMV.
Also, don't forget about inflation pressure. The more inflation in the tire, the harder it's going to ride. Obviously, you want the amount of psi to support the weight you are carrying. So, you can only "air down" so far before you risk tire damage. Some tires, like the KO2s, tend to wander if the inflation pressure is too high as well but not every tire is like that. Finding the happy medium takes some trial and error sometimes.
gaz
680
Wa, Bremerton 98310
87Ranger Endrigo 2.9l, 87BII Endrigo 4.0l
Ranger 5" (1½" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 33"/3:73LS
Deengineer until it is how Blue Oval should have sold it!!
@superj
How do you feel a 10 ply tire would hold up on a BroncoII at 3,500 lbs? How would it feel to drive, or two?
Junk Collector
Truck of Month
4,870
Rapid City SD
@superj
This is just my opinion but on a small vehicle, there is no downside to running a tire with more plies/higher load rating other than ride quality. You can be totally safe with a P rated/4 ply tire on a Bronco II or anything higher than that. Usually higher load ratings equal stiffer sidewalls. You can also run higher air pressure if you want. I usually run 40psi in the back of my Explorer and 35 in the front. I have 30x9.50x15 BFG KO2's on that rig. I think they are C load range/6 ply.
On the other side of that, if you have a large rig, say an F350, you should not be running low load range tires.
If I had a set of 10 plies in the size & style I wanted, I would have zero qualms about running them on a Bronco II.
rusty ol ranger
2.9 Mafia-Don
7,756
Michigan
177 CID
@superj
Itll pry ride a bit stiffer. But theyll wear like iron
superj
2,732
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
Yeah, just the ride would be rough and gas mileage will drop
gaz
680
Wa, Bremerton 98310
@superj ,
Why would the gas mileage be lower?
superj
2,732
ranger edge
none
none
235s
10 ply tires are heavier than load range c. They added ao much on my titan that my gas mileage went from 20mpg on the highway to 16mpg
