new member
newranger87
misouri
hello everyone. I’m wanting to get a model similar to my 1st truck and do a rebuild on it. I had a 1987 ranger extended cab, v6, 4x4. I want to build an off-roader/everyday driver. I want to add lockers, a 4.0 swap and run 31’s with needed up axles, a manual transmission, and would like to see if anyone makes a transmission with a granny gear. Any help would be appreciated. What should I be looking for when shopping for a truck.
Josh B
1,986
Oklahoma
Hello new ranger, seems you fairly well spelled it out in your description?
Not sure what I can add but there will be a number of folks saying howdy so you should get all the answers you need
Good luck with it
CamTheHedgehog
ASE Certified Tech
316
Charlotte, NC
Ranger Edge
4.0 SOHC
Torsion Bar Max Crank (Pre-2008)
Professional Dingus At Work
Hey! Welcome to the forum!
I don’t know much about the gen 1 rangers, but I believe they use the same BW 1354 transfer case, and there are a number of doubler units available for it if you want a crawl gear.
gaz
659
Wa, Bremerton 98310
Ranger 5" (2" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 29"/3:73LS
@newranger87 ,
I appreciate that you like the 1st Gen style but if you already know that you want an OHV 4.0l, perhaps consider the 2nd Gen 1989, as they are more set up for a 4.0l...or, possibly a 1990+ with a $tock 4.0l 👀. Either option will save you time/money and permit you to focus less on the swap, more on your other modification goals ..)
Lefty
1,847
Saint Paul, MN
Ranger Edge
94_PurpsRange
45
Menifee, Ca
30" all terrain
Pitter-patter, let’s get at ‘er.
Welcome to the thunder dome!
hahah i drive a 94 4.0L XLT... i would never go to anything else IMO... i kinda plan to do the same as you BUT right now im focusing on putting it on the road as a daily then i will begin the modification process :)
Welcome buddy!
superj
2,578
corpus christi, texas
ranger edge
3 liters of tire smoking power
none
none
235s
Grew up in the 70s, 80s, and 90s
SenorNoob
569
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
I second what gaz said. Unless you are prepared for some heavy wiring work, and absolutely in love with the 1st gen dash and grill. A 90-92 will have better hard parts and be a couple years newer.
1st gens will generally have a 2.9, FM146 (Except some very late 88. Usually 2.3 trucks only.), BW1350 with a slip yoke vs 1354 with fixed yoke, and a Dana 28 front axle instead of the 35. Not to mention the fact that a factory 4.0 truck should have a 28 spline 8.8 instead of the 7.5 rear.
Looking back, I'd suspect my truck would've been far easier to get a 90-92 and swap the fenders and grill.
