New project 1992 Ranger Fireball
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
Oh ok. Hopefully it's 17 or better!
shortzt
Did you have to cut down your front drive shaft if not what is your front drive shaft out of? If you did cut it do you remember the length
Elutheros
129
Central Texas
Yes I had it cut down. Used the worksheet from Denny's Driveshaft website to do the measuring and had it shortened to 28 3/8 inches. I also had to change the yoke on the front of the NP 205 to use the CV style yoke. I would recommend that you do your own measurements as the position of your engine will affect the required driveshaft length.
shortzt
I still have yo get the yoke and yeah I planned on it I just wanted a ball park area, thanks allot
Elutheros
129
Central Texas
the teenager in me could not resist
Picked these up at the JY today.
[/URL][/IMG]
Elutheros
129
Central Texas
Finally broke down and put a better size tire (33x10.50x15) on the Fireball. What a difference! Bonus points because I had a white speedo gear laying around which makes my speedometer exactly correct. Looks a lot better too.
[/URL][/IMG]
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
Having a v8 you don't notice they are on there either.
Simkins12
Austin, TX
Looks great! I need to come check out your install. I am in Round Rock.
Elutheros
129
Central Texas
Are you still working on an engine conversion?
Simkins12
Austin, TX
Yes sir. Truck is down right now with electrical issue but I am finishing up my research and hopefully pull the trigger on the engine & transmission soon.
300I6Ranger4x4
Chilliwack, BC
351w
We must do the things we think we cannot
Elutheros
129
Central Texas
Thanks for the kind words.
dangerranger83
54
Lafayette, IN
Any updates?
Elutheros
129
Central Texas
3000+ miles on the engine--running sweet, 15MPG. I drive it to and from a ranch I hunt on every week, about 100 miles round trip. Would be better if it had A/C, but I don't feel like messing with it right now. It's been hauling rocks for yard projects and other than some minor RABS issues, I have no complaints.
[/URL][/IMG]
