New ride
ryan
Forum Administrator
Administrator
905
Wayne, PA
6.0
Solid Axle Swap 4x4
I sold my buggy a couple weeks ago. It was awesome in some ways, but was really hard to work on and was not comfortable for passengers.
Ended up with this. It's a 94 YJ on tons, 42" pitbulls, ORIs and a brand new 4spd atlas.
ryan
Forum Administrator
Administrator
905
Wayne, PA
6.0
Solid Axle Swap 4x4
I got sliders from Kartek, because it looked to me that the original seats used the weld in karetk mounts. They're spendy, but much more beef than stock style, and lock in with a pin.
Compared to my buggy, getting these harnesses in was a breeze. This is with the seats all the way back, it's much more comfortable, though increasing seat high was a bummer trade off.
ryan
Forum Administrator
Administrator
905
Wayne, PA
6.0
Solid Axle Swap 4x4
I might be the last person to find out about these amazon spod knock offs. Wiring in my whip, radio and buggy whip were a breeze with this thing.
Plug the wires in, screw it down, and you're all set
Has a handy little panel to go with it
And now everything is up and running
ryan
Forum Administrator
Administrator
905
Wayne, PA
6.0
Solid Axle Swap 4x4
Getting the base tune on these was a little easier than I thought it would be. The lower valve controls the ride stiffness. ORI suggest setting to 100 psi as a base and then tuning from there, so that's where I'll start. One of the shocks had no air in it, so that would explain why things felt so off.
The top valve controls the ride height. I decided to bring it down a hair to keep the COG low, and then I can add to it if I need to. I'll bring the nitrogen tank with me on my first ride out in case I need to tweak anything. Will also need to open up the hole around the top valves in the rear to make it a little easier.
rusty ol ranger
2.9 Mafia-Don
7,662
Michigan
177 CID
Id drive the shit out of that.
What motors in it?
ryan
Forum Administrator
Administrator
905
Wayne, PA
6.0
Solid Axle Swap 4x4
What motors in it?
Still has the stock 4.0. At some point I'll probably go to a 5.3 or 6.0, but we'll see. The atlas makes up for the lack of a v8
racsan
4,499
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
I had a thought- with the tires that far outside the body you could put bigger (taller) ones on and drive it upside down if you flip over. (if you can figure a way for it to still get oil & fuel)
ryan
Forum Administrator
Administrator
905
Wayne, PA
6.0
Solid Axle Swap 4x4
I'll probably go to 43" stickies as soon as i can. Not financially feasible right now with tires at ~$1,000 each, but i'll keep an eye open for a used set
snoranger
Professional money waster
ASE Certified Tech
13,721
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
I saw your post of FB the other and started looking out the window at my Ranger sitting there. Then I looked out the other window at the shed where my Superduty axles are…
Stop giving me bad ideas!!!
ryan
Forum Administrator
Administrator
905
Wayne, PA
6.0
Solid Axle Swap 4x4
Cant swing a cat without hitting a SD 60 4 link swap truss these days. I'm excited to have options for axle shafts beyond branik now
ryan
Forum Administrator
Administrator
905
Wayne, PA
6.0
Solid Axle Swap 4x4
Got the crankcase vents replaced, waiting on a new air filter and spark plugs to come and I'll be done I think
Put the doors on and one is pretty banged up, adjusted it as best I could be its gonna be a problem child
ryan
Forum Administrator
Administrator
905
Wayne, PA
6.0
Solid Axle Swap 4x4
My to do list before the shakedown run is done, can't wait to see how it does on the trail
New ride height
superj
2,700
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
