New to this site.
aahmes57
2002 Ford Range
Hello all,
Somehow I got stuck itto this situation where my oldest son's truck was leaking brake fluid in the cab from the clutch pedal. Well the clutch master cylinder now turned into the slave cylinder which turned into the clutch pp and Tho out bearing which turned into the rear pinion seal.
You can't not do it when its all down. I guess.
Look forward to alot of experienced advice.
Thanks for your help in advance.
alwaysFlOoReD
5,166
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Welcome, there's lots of help here.
1]The tech library is at the top of every page, under the TRS banner, third button from the left.
2] The search button is directly above these posts, third button from the right.
3] If you can't find a solution, we'll be glad to answer your questions.
Richard
