oddball101
- Jun 8, 2010
- 0
- Columbia SC
- Ranger
- Engine Size
- 5.0
Hey guys, I'm reaching out here because I am at a loss. I have an '00 5.0 swap in my 01 Ranger Edge, and for the most part I have completed my M5R2 swap from the 4r70w. When the motor is running I cannot get it into 5th gear.
I had issues with the clutch not disengaging on any gears previously but I believe that was due to a slight misalignment with the rear of the tranny being slightly too high. Before I lowered the rear of the tranny, I installed an F550 master cylinder hoping it would resolve the issue, but ti did not. Only after lowering the rear of the transmission was I able to get it to cycle through the gears. I have not reconnected the driveshaft yet as I have to reinstall a newly fabbed (lower) tranny crossmember. The tranny is currently being supported by a jack stand for testing. The M5R2 came without a shifter but I've since installed a Core / Hurst shifter (as planned from the beginning).
Here's a pic of the slave throwout bearing resting on the clutch fingers. You can see where the centerforce ring teeth on the fingers have "trimmed" the blue plastic pieces upon compression.
Currently I have been testing functionality with the driveshaft removed but the rear end is still on jack stands. I was going to loosen the bell housing bolts and give her a shake but before doing that, I found that I could cycle all of the gears (minus 5th) with the motor running which was progress so I stopped there.
Here are some pics of my shift forks.
With motor off, I can shift through all gears effortlessly. With motor running, 5th won't even try and engage. It just sounds like a thud. No grinding, no popping out or anything. I have read that 5th and reverse go out together because they share a synchro, but I can get to reverse sooo is that still that same issue?
Is this just a sign that I will lose reverse too or could it be a sign that something else is going on that I may be able to remedy?
I have access and think I can remove the top cover if needed to inspect things.
I really need help figuring this thing out. Any advice is much appreciated.
