silverclaw328
- Feb 29, 2008
- 0
- Age
- 34
- ford
i just put a long block 4.0 ohv into my 94 ranger and everything checks out except for one thing. i have no power past a certain point on the throttle. I'll get decent acceleration to about 1/2 to 2/3 of the way on the gas pedal, about what you'd expect for not flooring it. Then, when i hit that sweet spot, all acceleration just stops. Here's a couple things i've thought of
clutch slip - i feel like i would definitly smell it if the clutch was slipping, the clutch kit and flywheel are brand new with the engine.
Unplugged sensors or vacuum leaks - double and triple checked all connectors and vacuum lines, nothing out of place or missing
throttle cable - nothing appears to be damaged, loose or missing.
PCM relearn - i drove the truck for a good 30 to 45 minutes and nothing changed. Does it take longer to relearn PCM or did i drive it long enough?
any thoughts on what i may have over looked or if i was looking in the right area would be much appreciated
