No blinkers or flashers
swynx
9
lewiston idaho
Mazda
Not even sure where to start looking for this problem
Every once in awhile my blinkers would just stop working then come back... now there gone for good. It doesn't click. doesn't flash on the dash and it doesn't flash outside.
willy
cedar lake, in
5.0 explorer
Check fuses if theyre all good check the bulbs if there not burnt check the flasher if thats good look at your multifunction switch (turn signal lever) if you have continuity in each of the functions and none are crossed then start checking grounds and power wires.
HGI
2nd gen
I had the same issue in my 92 ranger, ended up taking the multi function switch off and cleaned all the connections then plugged her back in and it worked as it it was new.
SenorNoob
587
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
I just cleaned the contacts in the Hazard switch on my mom's truck to get her turn signals working again yesterday. (Not a Ranger, '86 Nissan)
