No overdrive
joe72777
Just bought a 92 exploder. Took it out for a drive and there is no indication of a shift beween 3rd and overdrive. Can use shifter to shift and nothing happens at drive and overdrive. Rpms at 55 mph is about 2200-2300. Everything else shifts great. I have read that there is a shift silaniod that might be the problem but I thought that it would show up on the obd|| test. Or maybe somthing with the valve body. Just don't tell me I have to pull the crapmission.
Downey
Muncy, PA
do you have a switch to turn off the od? is your od light flashing?
joe72777
No switch that is used on the later models. No flashing light. Thanks anyway
Downey
Muncy, PA
well i tired hopefully someone else will help you out
Nhaz
4
The Great White North, Ottawa, Canada
1998 and a few
Ranger+Ranger+E
4.0 3.0
Check the passenger side floor for wet/dampness. Common problem of the wet floor can lead to the computer on the passenger side getting soaked.
A soaked and heavily corroded computer in my case was the reason my OD wasn't working.
joe72777
I will check but do not recall seeing that it was wet. May have been long before i bought it. Thanks I will check.
joe72777
nothing looks corroded any other thoughts
Nhaz
4
1998 and a few
Ranger+Ranger+E
4.0 3.0
I drove my a4ld without a OD for close to 7 months before I put in another tranny. (The replacements OD didn't work either which is how I tracked it down to my eec-iv computer)
The fuel cost in those 7 months wasn't really all that much more. Running a 3k didn't seem to bother anything at highway speeds.
irishblessing
Guest
is the fuse blown? on my ranger the fuse that runs the overdrive also runs the reverse lights i have a short somewhere and it keeps blowing that fuse so i took it out now i dont have overdrive or reverse lights
joe72777
Fuses all good guess ill drive it like i stole it. at least until it blows. thanks
