procadman
- Aug 20, 2013
- 0
- Ranger
I know everything points toward a clogged catalytic converter but Meineke says it's ok.
'89 2.9 auto w/overdrive and posi-traction.
75k on bottom end. 10k on top end. <30k on tranny. 150k on most other peripherals.
Compression is around 110 (to spec).
New wires, plugs, cap, rotor.
New EEC.
New EEC and fuel pump relays.
Timing is correct.fuel pump and filter is about 2 years old.
Has same size tires I have always had on it since new: standard ones in front and 50 series in rear.
Exhaust past converter has been replaced once and needs it again.
It was never good on gas: about 250m to a tank. Now it's just over half that.
Around town it has plenty of pull. But, when you get to 65 or 70 it's like stepping in a hole. There is very little pedal left and it makes no difference to use it.
Yes, all signs point to a clogged exhaust, despite what Meineke says, but, my experience with a clogged converter, though similar, has always included an overheating engine when you keep pushing it.
My code reader emits a constant beep and may be faulty.
Any other ideas, guys?
New EEC.
