No spark
Barbara
6
Michigan
Ford ranger
I'm going to replace the distributer and the pickup coil. Does anyone know how to mark it so I don't throw the timing off?
ericbphoto
Overlander in development
TRS 25th Anniversary
16,785
Wellford, SC
3.0L
6"
I turned my crankshaft until the rotor was pointing to the position for plug #1. Then made a mental note of about where everything was positioned. Put the new parts back in the same position. You will still need to fine tune the timing. But that gets you close enough.
19Walt93
4,503
Canaan,NH
351
3"
235/55R16
Keep in mind that the rotor will turn when you pull the distributor out, you'll need to remember -or mark- where it is once it stops turning. I'd pry the reluctor off and replace the stator unless you need the whole distributor, if the reluctor breaks it's cheaper than the whole unit. Whichever way you fix it the timing needs to be reset afterwards.
