Not working stereo
Timothy862
Firefighter
RI
Ford ranger
Hi guys I have a 2000 cord ranger XLT and I bought it with the stereo not working allready. I checked all the fuses and there good so I got a new unit off of fb marketplace ( it was working on his truck) plugged it in and it’s still not working. Any ideas on what’s wrong?
rumblecloud
1,133
48022
Ranger Splash
1-1/2 inch front leveling
Stock
What's the worst that could happen?
Is it doing anything to show signs of life?
Does it light up? Buzz? Antenna?
Are there speakers where they are supposed to be?
Timothy862
Firefighter
RI
Ford ranger
Yeah, it does light up but that’s it. Doesn’t buzz or anything. And as for the speakers I believe so haven’t thought about that.
09fx4guy
176
USA
Pre Key w/ #1 Bars
265/70R16
Did you verify that you have power at the connector? Grab a multimeter and check that. Fuses may be good but if somebody hacked the wiring at some point you may still have a problem.
Timothy862
Firefighter
RI
Ford ranger
Yup checked the voltage seems to be fine about 13v going through the connectors.
Eddo Rogue
2,503
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Mine had an aftermarket cheapo head unit, which worked fine until it didnt. I replaced it with another cheapo head unit. The aftermarket harness adapters looked exactly the same, but when I plugged the old one into the new unit, it did not work. I spliced in the new harness adapter, and it worked. It was weird because they looked exactly the same.
