Of course i had to mess with it
Beast4x4
Warrington, PA.
3.0L V6
so here is my problem. i have a pair 6 inch pro comp stainless 130 watt llights. i tried replacing the switch because i was going to mount it in a different location on the dash. when i swapped out the switch literally unplug and plug in the new, only one of the lights turns on. i put the old switch back and same thing only one light comes on. Anybody have any thoughts? I'm thinking that if i rewire everything that might fix it but i don't know. I did check the bulb on the lamp that does not turn on and the filament is not broken.
snoman6115
Weston, WI
v6 4.0
check for continuity from the switch tot eh actual light or to check if its gettin power to the light
nitrofan1
Man without a Ranger
MTOTM Winner
19
Chattanooga, Tennessee
Subaru
EJ251
Beast4x4
Warrington, PA.
3.0L V6
thats what i'm thinking. i think the one light that doesn't turn on the wires somehow got messed up. all of the connections are still tight and connected. i'm just gonna dive in an look i think
Crane
Kansas City, MO
4.0L SOHC
Do the lights have separate fuses? When I was mounting my Hellas, I was putting the switch in the cab after making sure they worked, and somewhere along the way, after i got the switch inside the cab, but before it was mounted in the dash, the lights wouldn't work. I checked the fuses, and one of the power fuses went out. Don't know how it happened, but it did, so just make sure you check those first.
Beast4x4
Warrington, PA.
3.0L V6
sorry for taking so long to reply, but i have checked all of the fuses and all are good. i'm planning on getting to it this weekend and double checking that all of the connections are still tight and secure. most likely i think that i got a wire loose
