I misread your post, but it still applies- just make sure you are using the filter for the pan, so in your case, get the 2wd filter along with the 2wd pan.
i purchased a complete engine out of 4wd truck to put in my 2wd same year & both had auto trans,i know the 4wd spin on oil filter is different &oil pan is different & of course oil pump pickup. i was thinking i heard that the 4wd pan would work on 2wd but not the other way around (but i don’t know that)was hoping to avoid starting the install & having to lift it out to change pans & pickup tube
well i called a ford parts dept. today,they looked up 1999 ranger 4.0 & said only one oil pan showed. didn’t show a different part # for 2wd or 4wd ! it’s 25 years old so i don’t know if their lists are as accurate as they used to be. what do you think ?
For
a small yearly donation, you can support this forum and receive a 'Supporting
Member' banner, or become a 'Supporting Vendor' and promote your products here.
Click the banner to find out how.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
