- Feb 28, 2001
- 4,541
- Dayton Oregon
- Ford
- Engine Type
- 2.3 (4 Cylinder)
- Engine Size
- 2.3 Turbo
- 2WD / 4WD
- 4WD
- Total Lift
- 6
- Tire Size
- 35"
'90 Ranger: fix whatever nuts hold the tailgate latches on, they're floppy. Fix the new auto lock feature of the drivers door, fix the screws for the front part of the center console, which completes the easy stuff. For the harder stuff finally make the extended radius arms I've had the parts for for like a decade... Oh, and put in the blue seats I grabbed last year...
'97 Ranger: add the rear side vent windows I picked up last year and the rear slider window along with the explorer overhead console.
'00 V8 Explorer: Merely completely remove the front suspension, replace it with a combo TTB D44 and D50 that I need to regear, pull the 8.8 and replace it with a 10.25" that I need to regear as well. Also need to pull the engine so I can add some material on the passenger side motor mount pad so it will hold the motor mount plate, and pull the timing cover so I can pull the bolt that broke off when I replaced the water pump a couple years ago...
'94 Geo Tracker: I'm pretty sure it's down to the fuel injectors not working but I haven't looked at it in a couple years.
Shop: call in an electrician and have them run the wire from the power pole to the shop so I can finally use it
Everything else: yeah, not sure, that's a whole other list that I don't keep track of, I just tackle things as they come up importance wise...
