Spitfire1975
- Nov 19, 2009
- 16
- Oregon
- Ford
- Engine Size
- 2.9
86 2.9 that is acting like it has a plugged catalytic converter. I have also been trying to fix a "miss" or "stutter" for the last year.
What it is doing:
a) "miss" at 2600 RPM under load.
b) slow and no power in the low rpm's, also no hill climbing power. Feels like it is surging a little as well when accelerating.
c) when first started (warm) will "hunt' for idle (~600-1000 before settling at 850-900)
d) when first started cold RPM's go to about 1500
e) Will stall out (sometimes) when A/C is on.
f) Engine temperature is a little hotter then normal (based on the gauge, not a thermometer)
What has been done to it:
NEW:
Distributor Pick-up sensor
Ignition Control Module
EGR system (all of it)
Radiator, water pump, heater core, thermostat, gauge sender
Ignition switch
Battery
Starter relay/switch
Coolant Temperature sensor
Coil
Cap, rotor, wires, plugs
Valve Cover, Intake Manifold, Throttle Body gaskets
Fuel Injector O-Rings
High Pressure Fuel Pump
Fuel Filter (several times)
Brakes, rotors and bearings
Muffler and tailpipe
Rear Driveshaft
Throttle Position sensor
shocks, sway bar bushings, tie rod ends and drag link
USED:
Charcoal Cannister
Knock Sensor
Air Temperature Sensor
Idle Air Control Valve (and cleaned it real well)
FPR looks new, but I didn't do it.
Catalytic Converter (couldn't see light through it but figure it was because of the dual cat setup)
Transmission (switched from TK5 to FM145)
Hard EGR vacuum lines
MAP Sensor
TESTS:
a) Fuel pressure at idle is about 30-31 lbs
b) Vacuum readings look normal, actually increase a couple of lbs when increasing RPM's? 21 at idle, drop to ~4 on quick accel., increase to 25 under quick decel. and settle back to 21. Run it steady at ~2500 RPM's and it sits at 23-24
c) Compression is about 150 each cylinder
d) NO CODES ARE BEING SHOWN (at the same time I cannot get a stored memory code when running the KOER test, but can when running the KOEO test)
d) all grounds seem to be good. I do not have a grounding strap connecting the hood to the engine compartment. Everything else seems to be in good condition.
e) I have seafoamed the engine, gas and oil (I run conventional 5W30)
f) mileage is about 16 city and 20 freeway on 235 75 15's with a 3.73 ratio.
g) Timing, with SPOUT removed, is set at 10*
I can't think of anything else.
Did I put in a bad Catalytic Converter?? The vacuum readings seem to say no, but the performance seems to say yes.
PLEASE, Ford mechanic guys........what the heck else can I do??????? Sell it?
What it is doing:
NEW:
Ignition switch
Battery
Coil
Rear Driveshaft
USED:
Charcoal Cannister
Knock Sensor
MAP Sensor
TESTS:
